026 parts
Discussion in 'Chainsaws and Power Equipment' started by JW IN VA, Dec 29, 2017.
  1. JW IN VA
    JW IN VA
    Virginia mountains
    Are parts for this model hard to get?Had someone tell me they were but I am having trouble believeing they are that scarce with all the ones still around.
    I know it's around 35 years old but this is simple fuel tank,air filter and impulse line.
  2. Armbru84
    Armbru84
    Sparta, Michigan
    Pretty sure I have a tank. But I won’t be back home for a little bit. There should be parts floating around.
  3. JW IN VA
    JW IN VA
    Virginia mountains
    Thank you.I have since found a tank.I think the guy was maybe saying the new OEM parts would make the repair more than the saw was worth.
  4. dall
    dall
    West Virginia
    which air filter is it the old style or new style both are still available and impulse hose is still available
  5. dall
    dall
    West Virginia
    on the impulse hose id go with a oem as i have seen aftermarket rubber hoses will only last a year to year and a half
    BuckthornBonnie likes this.
  6. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I may have a few 1121 lines left over. Will check. I agree with Dall, go oem on lines when ya can.
    I have handles, smalls, and air filters, too (if newer style).
  7. dall
    dall
    West Virginia
    On the air filter he will need to know if it is the one with the snorkel on carb and what filter cover
  8. JW IN VA
    JW IN VA
    Virginia mountains
    Thanks to all for your replies
  9. huskihl
    huskihl
    He was probably thinking of an 028. Only thing I know of on an 026 is the top cover badge is nla
  10. dall
    dall
    West Virginia
    Or maybe the 042/048
    huskihl likes this.
