Are parts for this model hard to get?Had someone tell me they were but I am having trouble believeing they are that scarce with all the ones still around. I know it's around 35 years old but this is simple fuel tank,air filter and impulse line.
Pretty sure I have a tank. But I won’t be back home for a little bit. There should be parts floating around.
Thank you.I have since found a tank.I think the guy was maybe saying the new OEM parts would make the repair more than the saw was worth.
which air filter is it the old style or new style both are still available and impulse hose is still available
on the impulse hose id go with a oem as i have seen aftermarket rubber hoses will only last a year to year and a half
I may have a few 1121 lines left over. Will check. I agree with Dall, go oem on lines when ya can. I have handles, smalls, and air filters, too (if newer style).
On the air filter he will need to know if it is the one with the snorkel on carb and what filter cover
