Presto logs
Discussion in 'The Wood Pile' started by FatBoy85, Dec 22, 2017.
  1. FatBoy85
    FatBoy85
    Washington State
    Oh I’m at my local hardware to pick up a new chain for my beast and come across this flyer outside the store.
    For the sake of the argument, I thought about lumping anyone’s experience with the other pressed logs threads here on their burn times. But first : Does anyone burn these get the inflated 12 hour burns?
    I have no intention of buying them. But maybe for a test?
  2. Matt Fine
    Matt Fine
    New York
    If you can limit the airflow they will certainly burn for more than 12 hours, but the heat output would be limited as well. The big question for me is the price. If the cost per BTU is less than I can acquire splits I will give them a try. So far, all the pressed wood logs/blocks/bricks I have found around here are 40% or more above local seasoned, split, and delivered hardwood prices. If I was extra lazy, I could actually pay to have wood delivered and stacked for me for less. Obviously it is way above the cost of doing your own cutting and splitting.
    MikeInMa and FatBoy85 like this.
  3. Warner
    At the top it says “save a tree burn me “ then says 100% wood ?
    This wood did not come from trees? Intresting
  4. FatBoy85
    FatBoy85
    Washington State
    It is and frankly I’m more into burning real splits. Even if I won the lotto I would stay burning, in fact it would perpetuate it.
    Long Burn times are what I am after but I would happily agree that within 6 hours the heat greatly decreases and becomes more of a coal. Ive burned duralogs before but these seem to be much more than that. More substantial as the consistency of the log was a lot like looking at a piece of OSB in a tube.
  5. FatBoy85
    FatBoy85
    Washington State
    Makes you wonder “whut iz thiz wüüd?”:D
    Suburban wood snob likes this.
  6. Matt Fine
    Matt Fine
    New York
    I think the idea is that they are made from sawdust, scrap and other “waste” so the tree wasn’t cut specially for their product. It is certainly a bit of a stretch. Like saying save a chicken by eating only dark meat. I am pretty sure it doesn’t make any difference to the chicken who eats the breast and who eats the thighs, he’s cooked either way.
    FatBoy85 likes this.
  7. JDU
    JDU
    Perry County, PA
    I was thinking the same thing.
  8. MikeInMa
    I was thinking that same exact thing.
  9. Suburban wood snob
    Suburban wood snob
    Milwaukee
    'what's the deal with the two Umlauts?' for the win, Alex
  10. FatBoy85
    FatBoy85
    Washington State
    Accents plus silliness.
  11. Suburban wood snob
    Suburban wood snob
    Milwaukee
  12. FatBoy85
    FatBoy85
    Washington State
    Nitch viel. But yesterday lubricant in the form of brandy was involved. :whistle:;)
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Sehr gut!
  14. FatBoy85
    FatBoy85
    Washington State
    Prosit!
  15. dotman17
    dotman17
    Snohomish, Washington
    Would you consider Idaho Logs a presto log?
  16. MikeInMa
    Idaho logs - compressed potatoes?
    tamarack, FatBoy85 and milleo like this.
  17. milleo
    milleo
  18. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Don't laugh. Throw your McDonald's fries on the fire! Sure there's plenty of btu's... And grease!
    milleo and FatBoy85 like this.
  19. FatBoy85
    FatBoy85
    Washington State
    Im ok with this. Its really just asking if you may have burned both and know a difference...
    tamarack and Vanngard like this.
  20. dotman17
    dotman17
    Burning manufactured, high heat logs are pretty nice. They do generate a lot of heat and if your not careful, you can overheat your stove. I have an infrared thermometer which I use to ensure I don't invalidate the warranty on my stove by over-firing. When I have a fire box full of red hot coals and I drop an Idaho Log on it, the thing can scarily raise like 200 degrees. I often can only burn the one log safely with maybe a single cut of wood. And they burn about 1.5 hours.
