Dragon action.
Discussion in 'OWB's and Gasification Boilers' started by Heat550, Dec 22, 2017.
  1. Heat550
    Heat550
    Minnesota
    Slabs coaling up between burn cycles ..man there is some serious heat. 36 wide 54 deep.
    I figured it out I can get 1000 lbs of slabs in there. How's that for Dragon action ?
    Heat550[​IMG]
    Sent from my LG-H900 using Tapatalk
  2. Camber
    Camber
    Montana
    Man. That sucker will hold some fuel!
  3. Blstr88
    Blstr88
    What boiler do you have?
  4. Heat550
    Heat550
    Minnesota
    Heatmor 400 ( 400,000 BTU max output )
    300cfm of draft fan. 2 dragons (fans) one on each end.
    Heat550
    SKEETER McCLUSKEY likes this.
  5. Heat550
    Heat550
    Minnesota
    More Dragon action . Oak slabs burn hot.
    Water was going from 80f to 150f at -13f
    It was pulling hard . Didn't take long to hit 150f .. that's a 6 foot extention. I had the cap on to slow things down .. but I'm going to need choke off on fans to stop wood wasting.
    Heat 550
    Heat 550[​IMG]
    Stlshrk and SKEETER McCLUSKEY like this.
