Deep fried turkey help !
Discussion in 'The Smokehouse' started by J. Dirt, Dec 21, 2017.
  1. J. Dirt
    J. Dirt
    Going to try one this weekend and maybe make it into a Christmas Eve tradition. The question is do you guys brine or not and do you inject or dry rub or just fry the bad boy plain with nothing but the peanut oil?
    Eric VW likes this.
  2. OhioStihl
    OhioStihl
    Southern Ohio
    I applied a dry rub on the outside of the bird and under the skin where possible. Also injected melted butter and seasoning through the bird. Brining would probably make it nice and moist.
    I also mixed up hush puppy mix and dropped spoonfuls of mix into the oil when the bird came out. They float to the top when done. Nice little addition to the dinner
    Eric VW, Scotty Overkill and J. Dirt like this.
  3. J. Dirt
    J. Dirt
    :drool: I really like the hush puppy idea! Did you shoot it with butter and the same seasoning as the dry rub?
    Eric VW and OhioStihl like this.
  4. Babaganoosh
    Babaganoosh
    Jersey Shore
    Don't brine it too long. It comes out salty.
    Do a test run with water to see how much oil you need. It helps a lot.
    tamarack, Eric VW, OhioStihl and 2 others like this.
  5. J. Dirt
    J. Dirt
    That’s what my Dad said about the water test for oil level. I borrowed his fryer just to see if it’s worth me getting my own.
    Eric VW and Scotty Overkill like this.
  6. Scotty Overkill
    Don't forget to take pics!! And an invite would be nice.....;)
  7. J. Dirt
    J. Dirt
    I’ll snap a couple shots for sure! As for the invite come on over but you may want to bring a pizza as a back up plan :rofl: :lol:
    I’m sure it will turn out fine I’ve got to watch the weather though might be in for some white stuff Sunday we shall see
    Eric VW likes this.
  8. J. Dirt
    J. Dirt
    Winter took a few days off now it’s coming back! 46B35413-47BD-4D6A-9A71-AA6AD773B2DE.jpeg
    Eric VW likes this.
  9. OhioStihl
    OhioStihl
    Southern Ohio
    Good advice. I forgot about that one. I would do the water test and just leave a small mark with a sharpie to mark the level.
    Eric VW and J. Dirt like this.
  10. OhioStihl
    OhioStihl
    Southern Ohio
    It’s been a long time but I’m pretty sure it was two different seasonings. The skin tastes great but I tend to eat the skin and the meat separately
  11. Matt Fine
    Matt Fine
    New York
    I would dry brine and inject. If you use a set brine, make sure to leave time to fully dry the bird before frying. Moisture plus hot oil can foam and splatter which combined with an open flame can produce an incredible fireball.
  12. Babaganoosh
    Babaganoosh
    Jersey Shore
    Oh. And don't do it in your garage. Remember clearance to combustibles!
    You are gonna drip oil. Make sure it's somewhere it won't bother you.
  13. J. Dirt
    J. Dirt
    Going to be in the driveway providing the snows not blasting if worse comes to worse under the overhang of the barn which is 15’ high and wide open
    Eric VW and SKEETER McCLUSKEY like this.
  14. CDF_USAF
    CDF_USAF
    Dover DE
    I do a dry rub of season all, garlic powder, and onion powder. I have injected with mixed results, and even just plain is a safe bet. I did 6 birds for a wedding last spring and did injecting and plain rub, there wasn't any leftovers. Reguardless of where you do it, turn the burner off when you put the turkey in and out, there will be some buble over or splashes of oil. Also a handy tip, line an old cooler with foil to let it rest in, makes a nice moist bird if you over do it. Have fun, 3.5 min per pound at 325-350. Rough calculation of 3 beers while bs'n.
    brenndatomu, Eric VW and J. Dirt like this.
  15. J. Dirt
    J. Dirt
    :D:yes: Picked up an injector today! Thought I had one but last night upon closer inspection :picard:
    Eric VW and CDF_USAF like this.
  16. CDF_USAF
    CDF_USAF
    Dover DE
    It happens, I have about 4, and just as many thermometer's....somewheres...
  17. huskihl
    huskihl
    Deep fry one and smoke one. And then report back please
    Eric VW, Camber and J. Dirt like this.
  18. TurboDiesel
    I like that idea. This was a few years ago
  19. J. Dirt
    J. Dirt
    Holy meat feast!!!!
    Thor and Eric VW like this.
  20. Eric VW
    Holy double meat feast.... mite even call it a meat FEST!:drool:
    :thumbs:
