Unloading stove from truck...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Lucy, Dec 7, 2017.
  1. Lucy
    Lucy
    Arkansas
    We are finally picking up our stove on Saturday. Have no idea how to get it safely off the back of the truck. I keep thinking of those You Tube accident videos :hair:and our nice stove in pieces at the bottom:picard:
    We've got a couple old 2x8 board ramps that were used for a motorcycle a long time a go.
    Please any life saving ideas?
  2. MightyWhitey
    MightyWhitey
    Rent a trailer that sits relatively low to the ground.
    wildwest and TurboDiesel like this.
  3. Grizzly Adam
    Grizzly Adam Guest
    Is there a nearby hill you can back up to and roll it on cart from there?
  4. Lucy
    Lucy
    Arkansas
    We've got a trailer but the roads we have to drive to get the stove are very bumpy. We are worried that it will get rattled loose, the trailer bounces a lot.
    We'll take all the bricks out just in case.
  5. Lucy
    Lucy
    Arkansas
    No, not steep enough. I fear that once the stove starts sliding down the ramps it may develop a life of its own.
  6. CDF_USAF
    CDF_USAF
    Dover DE
    This guy has a pretty good method, maybe you could adapt it to your situation.
    Doug MacIVER, Lucy and wildwest like this.
  7. woody5506
    woody5506
    Upstate NY
    Probably a stretch but if you are that worried it could be worth renting a box truck with a lift gate. Not the cheapest route but I don't imagine it being much easier.
    The Wood Wolverine, Lucy and wildwest like this.
  8. chris
    get a come-a-long use that to control the progression down the ramps , 1/2 ton ones are not pricy. You would want anchor it to a very stout rope , chain, or ratchet strap anchored to both front corner tie downs in the bed. The inexpensive ones do not have the longest reach so you need something in between . A heavy duty 2" wide ratchet strap works well. Heck we have even used a rachet strap in desperation to pull a car on to my 5 ton trailer. Once have a come-a-long you will find quite handy for many other applications. By the way a 2x4 or 4x4 spaning a door way Plus the come -a-long makes moving these blocks of metal and stone almost fun.
  9. OhioStihl
    OhioStihl
    Southern Ohio
    Cook a big spaghetti dinner and have a bunch of people over.
  10. TurboDiesel
    Rolls and Kari dolly.
    $35 per day at the rental center near me.
    I put a 900 lbs safe in my main level and a 650lbs IS out of BrianK's house onto a trailer and into my basement. So easy a caveman can do it!
    This is BrianK and his son moving the 450 lbs Fireview out of his house when it came to my house. The IS move went just as easy.:yes:
    Mag Craft, milleo, WeldrDave and 3 others like this.
  11. Lucy
    Lucy
    Arkansas
    What a beautiful stove. Thanks for the video.
    FatBoy85 likes this.
  12. Lucy
    Lucy
    Arkansas
    I think you have something there. We have an old one we use for logging.
  13. Lucy
    Lucy
    Arkansas
    Thanks guys, a lot of good ideas. Maybe I'm just too worried. I try to get some pics of how it works out.
  14. TurboDiesel
    When we picked up the IS stove from Tom in DC. He had a power dolly that worked like a forklift. He picked it up from the back of his van and set it on the back of my truck. I don't know where you could rent one, but it was really easy.
    I'll see if I can find a video
  15. TurboDiesel
    Can't remember for sure if it was power or hand crank but it worked like this
  16. Lucy
    Lucy
    Arkansas
    Yes that would be perfect. No idea where to get one though and probably expensive.
  17. Grizzly Adam
    Grizzly Adam Guest
  18. Lucy
    Lucy
    Arkansas
    Yes, those are pretty neat. I looked at Harbor Freight but they are a bit pricey and then i'd have to store them later.
  19. Grizzly Adam
    Grizzly Adam Guest
    But you might be able to rent.
  20. Lucy
    Lucy
    Arkansas
    I look around tomorrow and see if i can find anything useful.
