How to get stuck buckets apart?
Discussion in 'The DIY Room' started by Midwinter, Nov 30, 2017.
  1. Midwinter
    Other than brute force, of which I have very little? Anyone have a trick? IMG_20171130_13678.jpg
  2. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    I stick the tapered nozzle I use when blowing up snow tubes, pool floats, etc and I stick it between the sides and give it a blast of air.
    Just to add ; I do this dozens of times each spring when I start tapping maple trees and need to get my buckets apart.
  3. Warped5
    Warped5
    Northwest IN
    Put them in hot water for a few minutes.
  4. Midwinter
    Wow, thanks! We have an air compressor, so we'll try that first. If that fails, into the bathtub!
  5. Canadian border VT
    if you get a gap squirting some wd40 with air might help
    brenndatomu likes this.
  6. chainsawsoldier
    chainsawsoldier
    NE Kansas
    Put a piece of baling twine in the bucket before stacking:D I usually have to pull several apart each year. Also putting ratchet strap around bottom bucket holding it to post or something similar allows you to pull harder- also a pair of vise grips or pliers on top handle help you to pull apart.
    Or you can run hot water over bottom bucket to expand bucket and air pocket, allowing top bucket to slip out.
    Charles
    brenndatomu and Midwinter like this.
  7. JIMBETHYNAME
    JIMBETHYNAME
    Poughkeepsie ny
    Hold the buckets upside down and take a hammer and tap the rides on the lowest bucket. Pops right off:thumbs:
  8. Midwinter
    So many different methods! Tomorrow I'll try them all. At least one or two should work! Thank you!
  9. Midwinter
    Success! I told my husband about all the various suggested methods, and here's his: put them near the wood stove for a little while to warm them up. It worked for the three, but the yellow & white ones were still stuck. So I banged on those with a hammer, and that did the trick. Now I can clean 'em up and use them for branch nubs and kindling scraps. IMG_20171201_3765.jpg
  10. schlot
    schlot
    NW Iowa
    Dynamite :)....ah, too late.
  11. yooperdave
    Sawzall!
    WeldrDave, papadave, LongShot and 3 others like this.
  12. krooser
    krooser
    Waupaca, WI
    Which method do I use on two stray dogs?
    brenndatomu, papadave and yooperdave like this.
  13. yooperdave
    A bucket of cold water....before they get stuck!
  14. brenndatomu
    Garden hose...
    WeldrDave likes this.
  15. WeldrDave
    Exactly! Squirt a hose on the lip of the bottom bucket, water will work it's way into the bottom bucket and pop the upper bucket out/off. :)
  16. Midwinter
    I'm not doing that with those stray dogs in the yard!
    brenndatomu, papadave and WeldrDave like this.
