Ridgewood
Discussion in 'The Wood Pile' started by thewoodlands, Mar 8, 2014.
  1. thewoodlands
    thewoodlands
    This ridge is loaded with downed wood from last years wind storms, the big Cherry is up further but I'll start on this Maple (Sugar I hope) once the snow melts a bit more.
    I would like to be done with it by the end of June if not before, it's a chit load of wood so I'm not sure if it's doable.
  2. papadave
    Busy, busy, busy.
    thewoodlands likes this.
  3. Smokinpiney
    Smokinpiney
    "South" Jersey
    That is all of wood! Careful gettin those hangers down.
  4. thewoodlands
    thewoodlands
    Will do, it will be a nice trail once I get it cleaned up.
    Most of the trees down are Cherry but we have some Maples down too, since there down I'm hoping for Sugar.
    papadave likes this.
  5. Certified106
    Certified106
    In The Hills
    Wow that is a bunch of wood! How many cords do you think there are down?
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Love that cherry! Each time I go to my uncle's cabin in ny and I'm amazed by the size of the cherry trees on his property. They're not that common in my area
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Fan of Cherry as well !! Wish I had some slopes on my property like that ! I guess they are good to look at..but make it more challenging to get work done :)
    greendohn likes this.
  8. SolarandWood
    SolarandWood
    Syracuse NY
    Hey Zap how do you deal with moving all the material? Cut into pieces that the winch can pull out to a roadway or do you block in place and hoof it? Do you then make special trips to pick it up or just always cruise around with the trailer behind the Rhino and pick it up when convenient? Very little of our property is accessible by truck nor will it ever be and I'm trying to figure out if I'm better off skidding with a small tractor or blocking in the woods like you do.
  9. Well Seasoned
    Nice its all in one area to work at a time. Hoping for more snowmelt here soon so I can finish 15/16, & get started on 16/17
  10. SolarandWood
    SolarandWood
    Syracuse NY
    Gotcha, so work a spot until its cleaned out and make as many runs back and forth to get the wood out to your stacks? With your Rhino/trailer setup are you backing right up through the woods to the blocks or do you hoof them out? How much per trip? Half a face?
  11. thewoodlands
    thewoodlands
    I can get to the ridge two different ways, through a small meadow on the south side, or on the north side. I'll split most of the wood at the base of the ridge in the meadow.
    This year I might haul more of the split wood out by the Ford 250, some I'll use my regular setup. I'll end up rolling the splits down the hill into the meadow then split.
    Most of the hills on our property have trails/roads running to or on them.
    Stinny likes this.
  12. thewoodlands
    thewoodlands
    I'm not sure on the total but my guess would be 4 cord down on this ridge, hope it's more. I'll fill the new stacking area real quick this year.
  13. thewoodlands
    thewoodlands
    This is an easy one to work compared to a few of the other hills.
    HoneyFuzz likes this.
  14. Stinny
    You sure are right Wood… that's a chit load of trees! Have fun opening up your trail there. And, look out for those widow makers.
  15. thewoodlands
    thewoodlands
    Yes, this area I'll be able to drive to the rounds with the splitter, then haul it out with the small trailer or truck.
    Most of the hills have a trail that runs at the base of it, I just need to roll the rounds down. I think two loads in the small trailer is just over half a face cord.
    I have a few small dead trees that I need to cut on the trail around the house that will allow me to drive the big truck to the stacks by the house, save some time and money.
    I just have some downed basswood in the meadow that I'll need to clean up so I can get in, about a one hour job.
  16. thewoodlands
    thewoodlands
    Only one problem, I hate working just one area. I was surprised when I went out on the sled today on the county trails, they were great, I was thinking we (my nephew was with me) would see more bad spots from the sun melting the snow.
    According to AccuWeather we have a night coming up (Wednesday or Thursday) with a realfeel of -22, I think it's March 12. We'll get through this last bit of winter Mother Nature throws at us.
  17. Stinny
    Don't know if you read a post a while back about the 24" wet snow storm on March 31st 2001. Doozy. Winter does happen in March and April doesn't it?
  18. thewoodlands
    thewoodlands
    Yes, I've lived in northern ny all my life, boy do we realize winter is not over.
    Stinny and papadave like this.
  19. papadave
    Keep hearing weathercasts about this "endless winter".
    Huh?
    When has winter ever been over in the middle of February? I've been around a couple years, and I don't remember one.
    Baffles and confuzzles me.
  20. thewoodlands
    thewoodlands
    This is my path to that ridge, just some small clean up before I can get in with the rhino or truck.
    SolarandWood likes this.
