Trucks getting bigger!
Discussion in 'The DIY Room' started by swags, Feb 25, 2014.
  1. AmarilloSlim
    AmarilloSlim
    Amarillo
    You still running factory 3.54? Ring and pinion ratio? For the record big tires are like fake t%#s. Play with em' awhile then you want a bigger set.
    eatonpcat, OhioStihl and clemsonfor like this.
  2. MasterMech
  3. OhioStihl
    OhioStihl
    Southern Ohio
    My truck needed tires last fall. I stayed with the stock size. I don't want to lift wood and cargo any higher than I have to. My neighbor needed help unloading a fridge from his lifted Superduty. That was a real treat.
    clemsonfor likes this.
  4. clemsonfor
    Yea my K10 is tall enough. Id like 38s on it and about 6"s but like you said lifting wood... plus I dont want to buy $1200 worth of tires. IMG_20140112_172548.jpg
    basod, Carbine, Chvymn99 and 2 others like this.
  5. smoke show
    smoke show
    Pittsfield, Wi
    Nice truck!
  6. clemsonfor
    Needs paint. There is spray paint covering rust that I cleaned up. But if I paint it I will feel bad for using it.
  7. AmarilloSlim
    AmarilloSlim
    Amarillo
    Toss in a gm corporate 14 bolt with an add a leaf.
    smoke show and MasterMech like this.
  8. clemsonfor
    In 80 they put the 12 bolt in them so at least I have that one
  9. AmarilloSlim
    AmarilloSlim
    Amarillo
    No offense but the 12 bolt is a nice way of saying 10 bolt.
    smoke show likes this.
  10. clemsonfor
    So what is the 10 bolt? Did they just put 2 more bolts in it? I was under the impression the 12 was better than the 10 but I know not as good as the 14.
    Heck if I had the money why not just out rockWells under it?
  11. AmarilloSlim
    AmarilloSlim
    Amarillo
    The 12 bolt is a slightly beefed up 10 bolt at best. The 14 bolt is made in two diameter ring gears. One is semi float the other is full float. Rock wells and 44 boggers will net ya 18 inches of ground clearance under both pumpkins though!:eek:
  12. AmarilloSlim
    AmarilloSlim
    Amarillo
    For clarification the 10,12,14 bolts have "x" number of bolts holding the ring gear to the case ( probably a gov lock/bomb) not the differential cover bolt count as most think is the proper way to distinguish.
  13. clemsonfor
    U learn something. I thought it was diff cover bolts? Hmm m how did I not catch that in all those years of reading petersons 4wd?
    AmarilloSlim likes this.
  14. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    That truck is SEXY Dexter.
    DexterDay likes this.
  15. smoke show
    smoke show
    Pittsfield, Wi
    14 bolt FF ftw!
  16. clemsonfor
    What?
  17. nate
    nate Banned
    Palmer, AK
    10 and 12 bolt do happen to have 10 and 12 ring gear bolts, but a 14 bolt only has 12. (not sure on the 9.5" 14 bolt... Haven't ever messed with one)
  18. clemsonfor
    Thats what I thought I remembered. Pert persons 4wd has had axle identification articles and I was sure that you counted cover bolts. But I am no expert. Pretty good mechanic but no expert. I also have never built a truck so I am not a component guru.
  19. MasterMech
    What? No love for the Dana 70 that's under my '89 C3500? :D
    RockyMtnHigh and AmarilloSlim like this.
  20. Carbine
    Carbine
    I would love to have that truck.
    the GOAT likes this.
