Firewood BTU and the perfect firewood question/intro.
Discussion in 'The Wood Pile' started by Norman, Nov 17, 2017.
  1. brenndatomu
    Yeah, especially with (2) 90s in the pipe. And a chimney fire with a Boxwood stove would be a bad deal because they are anything but airtight...extra rockety sounding it would be! :eek:
  2. blacktail
    blacktail
    PNW
    Burning garbage, treated wood, and wet wood, in a window-vented vogelzang.
  3. Norman
    Norman Banned
    deep in the Appalachia mountains
    yes i do have creosote!... i drilled a small hole in my 9o's just large enough to install a small bolt to use as a plug,, about every two months i go out, remove the plug, and use a home made "shovel" and stick up there thru the hole and clean out the bend..usually get couple cups of "ashes" to pour out the whole... my pipes have been up 2 yrs and just recently replaced my outdoor 90 due to rust holes.... from there, running horizontal thru the wall to the stove, i had around 35-40% restriction which i cleaned out.. next year it will be time to replace all the pipes... am thinking about running the pipe vertical thru the roof as it should... and will definitely have to use some triple wall up there and do it right.... my current setup would probably make most people cringe... leaky boxwood stove, 2ft of 6in flue... a 90,, then 4ft of flue out an old window boxed in with sheetmetal.... another 90 elbow.... and 4ft more of flue going up with a gas ventcap on top.. flu is about 12 in from side of my residence where it goes up so i don't worry about catching the side of the house on fire,,,it is secured with metal coat-hangers no less! It was designed with what money i had to spend, which was very little... (i get very nervous on windy days tho, i could probably shove it over outside with my hand!) .. last year, before i drilled and plugged the aforementioned holes in my 90's.. i had a habit, when my draft wasn't very good, to go outside and smack the flue with a broom handle and dislodge all the built up creasote.. my draft of course got better.. when after i say about 10 episodes of this it eventually blocked off my 90, resulting in a very smokey house, and very pizzed off wife. so thats why i drilled the holes.... ya.. i need to go thru the roof... ---------too bad my son busted out the window i removed or i would have had a window to go back in the hole... If i burn all the garbage i can that my household generates, i never have to make a trip to the burn barrel.. hehehe... treated wood? yea ill burn it.. i hear its toxic,, probably is... but the smoke goes outside and dissipates, therefore i don't breath it.. or too much of it anyways.. maybe it will poison some of these mosquitoes Couldn't be no worse than seeing a hvac guy do 100's of jobs,, while letting all the r-12 escape into the air...he says reclaiming it was too much time and money.. gotta do what ya gotta do... maybe one day i will be 100% compliant with the oath of responsible wood burners :) burn on my friends!
    greendohn likes this.
  4. Norman
    Norman Banned
    yea mate.. thats me... (for now im hopeing its temp)
  5. JPDavis
    JPDavis
    Prescott, AZ
    Best that I've burned, Black Locust or any type of Locust, Honey or Sunburst and even Purple Robe. They all burn for a bit and put off a lot of heat.
  6. Norman
    Norman Banned
    My uncle had a Fisher papabear.. id love to have that here.. kinda big tho for a mobile home tho..:)
  7. Warner
    Welcome! Burning your family’s residence is no joke, stay safe. I am a firm believer in do what you gotta do till you can do better. But burning garbage is is poor form my friend. To each their own.
  8. Norman
    Norman Banned
    here she is in all her glory... $200 stove, $60 in flue, enough to keep you warm.. does pretty good, i feel safe.. i think anyone can burn within epa standads if they have enough experience in using a stove.. just the right damper setting, with just the right air supply.. no smoke out flue, just pretty heat waves!... i think epa stoves are designed so that anyone, no matter their experience, can throw in a chunk of wood and use the stove and be within epa guidlines.. to me you can't really tweak an epa stove everything is kinda pre-set... i probably coudn't burn my garbage in an epa stove.. what good would that be? heheh ..
      File size:
      262.7 KB
      51
  9. Pallet Pete
    Pallet Pete Moderator
    Ovid
    What?
    Norman you make no sense. I can’t even debate with you because your statements are so far off reality.
    I burn pine and love it heck there’s parts of the country where that’s all they burn......
    Welcome Norman I hope your alive come spring!
    O my head:hair::picard:
  10. Norman
    Norman Banned
    Too far off reality? lol.. its they way we do things in our local part of the sticks... im not the exception... its the rule around these parts!
  11. Pallet Pete
    Ovid
    Which part of the stick do you live on?
  12. WeldrDave
    Norman, First welcome to the forums... With that said, "Please" consider your above post to be admittingly "Unsafe"! Also, The danger you put yourself and your family is possibly a grave circumstance. I would re-think your burning pratices for safety sake. I'm not here to bash or pick on you but our site is to promote "Good" and safe burning habits as well as doing it as earth friendly as possible. Noboday here wants to see you injured but please think again on how and what your burning, and I'm sure if you reached out for help, someone would assist if close. :)
    Dave.
  13. WeldrDave
    That Zip code is West Virgina, I was near there in September.
  14. oldspark
    oldspark
    NW Iowa
    I thought maybe Norman was pulling our leg but now I wonder.
    He makes some statements that I agree with and some that are silly.
    His set up and burning garbage burning is something I would never do as that is the recipe for a chimney fire considering the wet wood he is burning.
    Good luck Norm, we're pulling for ya.
  15. FatBoy85
    FatBoy85
    Washington State
    His stove and set up is one that reminds me of the thread MightyWhitey set up.Another Neighborhood Wood Burner............I think??
    Shoot.
    I believe if he keeps posting, he’s luring everyone into this game he calls “Garbage”, seeing whoever picks up on it....
  16. Splitsnstacks
    Splitsnstacks
    Sw pa
    Oh boy..I too wish he were joking. I however whole heartedly believe he is being truthful lol. Reason being, I could take you to at least 10 households in my town of roughly 500 people in which this is common practice. And these are the same people that have chimney fire after chimney fire and still .. they still don’t understand what is causing it! :rolleyes:
  17. MightyWhitey
    MightyWhitey
  18. Norman
    Norman Banned
    Oh....it does produce tons of creasote...i clean out my flue about once a month...gonna srart a new thread about what i found today....should be a fun read....
  19. North woods
    North woods
    Wisconsin
    I think red oak is my favorite. Good seasoned red oak burns good and really holds the coals. I like black locust also but it can get to hot for my liking if I don't mix something with it. Been burning soft maple right now that is seasoned nice heat but doesn't hold the coals great.
  20. Moparguy
    Moparguy
    TN
    Hands down the hottest burning wood you can get is Osage Orange and Persimmon. Everything else burns hot, but not like these 2 do.
    FatBoy85 likes this.
