Makita dsc6000i rebuild
Discussion in 'Chainsaws and Power Equipment' started by Shawn McNally, Mar 8, 2014.
  1. Shawn McNally
    Shawn McNally
    Page, AZ
    I just acquired a Makita DSC6000i I'm wondering if anybody knows much about these saws. Is it the same as a Dolmar PS 6000i? Any help you can give me regarding this saw will be great. I don't even know what is wrong with it yet. Any tendencies? Where is the best source for parts?
  2. w8ye
    w8ye
    Mansfield, Ohio
    The Makita 6000i is identical to the Dolmar 6000i except the Makita is blue and the Dolmar is a redish orange.
    Just use Dolmar repair items.
    Cylinders are scarce
    The 6800 is the same chainsaw except for a larger bore.
    The Dolmar 116S has the same cylinder and piston but it has to be the "S" version. Dolmar 120S has the larger bore of the 6800.
    MasterMech likes this.
  3. Shawn McNally
    Shawn McNally
    Page, AZ
    Looks like I need a piston . It is not scored but it is torn up. Not sure what happened? There is a hole along the edge of the piston and the piston ring went bombshell in the cylinder. Cylinder doesn't appear damaged. Any ideas? The hole appears mechanical not burned trough.
  4. Carbine
    Carbine
    See if you can post a couple pictures of it. You have my curiosity peaked, the Makitas of that size and era aren't all that common either.
    Shawn McNally likes this.
  5. w8ye
    w8ye
    Mansfield, Ohio
    Typically some small part of the engine goes up through there?
    Needle bearing
    Main bearing cage
    Circlip from wrist pin
    Pin that keeps ring from turning
    Ground electrode from spark plug
    You can get a Meteor piston much cheaper
    Carbine has used the Dolmar 6000iH in the pictures below. The Makita is Blue/black
    Here are pictures of the corresponding Dolmar 6000iH for reference.
    Shawn McNally and Carbine like this.
  6. Shawn McNally
    Shawn McNally
    Page, AZ
    image.jpg image.jpg the marks on top of the cylinder match the profile of a section of the piston ring exactly !!
  7. w8ye
    w8ye
    Mansfield, Ohio
    Looks like the ring pin came out?
  8. Shawn McNally
    Shawn McNally
    Page, AZ
    So that makes sense! Based on its location. I don't see any damage to the cylinder. Just ordered a new piston. Any other ideas on what I should be looking for?
  9. w8ye
    w8ye
    Mansfield, Ohio
    This series of chainsaw is pretty straight forward. I've had the one in the pictures all apart and it went back together with no big problems. It didn't have much time on it as a 6000i and I made a 6800i out of it.
    This is a video of my 6800iH with a guy from Cincinnati running it at a GTG last fall . . .
  10. Shawn McNally
    Shawn McNally
    Page, AZ
    I keep seeing gtg. what is that?
  11. w8ye
    w8ye
    Mansfield, Ohio
    Get Together.
    A bunch of chainsaw guys get together and use each others chainsaws to cut thin pieces off logs called cookies. It is a good way to see what other chainsaws are like and for old friends to meet up and shoot the breeze. Sort of a chainsaw party. It sometimes gets into chainsaw comparisons or races etc.
    One of the guys is the host and the others pitch in to help defray the costs.
  12. Shawn McNally
    Shawn McNally
    Page, AZ
    What does it take to bump it to
    a 6800?
  13. w8ye
    w8ye
    Mansfield, Ohio
    A piston/rings and a cylinder from a 6800 or 120S.
    Cylinders are hard to find.
  14. Certified106
    Certified106
    In The Hills
    Looking forward to watching this thread progress!
  15. DexterDay
    Shawn, welcome to the Forums!!
    Dolmar and Makita make a fine saw! These guys will set you straight in parts and people who may have them.
  16. w8ye
    w8ye
    Mansfield, Ohio
    I had been wanting to make my Dolmar 6000iH into a 6800 ever since I bought it in used the spring of 2011. Cylinder/pistons were available from the distributors then. I kept putting it off until this time last year and there was not a cylinder available any where. Not even on Ebay.
    I just so happened to stumble upon two new 49mm bore cylinders that a guy in Oregon was trying to sell on Ebay. They were not listed as Makita or Dolmar but just as 49mm. He had bought out a out-of-business chainsaw shop some years before and was just selling off the junk. I could see from the detailed pictures that they were for a 6800. So I bought one for $50. I then bought a Meteor 49mm piston for $30 and away I went. -Dolmar 6800-. It has run perfect before and after.
    The Dolmar 116Si/120Si and the the Makita & Dolmar 6000i/6800i are just sweetheart chainsaws that everyone loves who has one. They quit making them along about 2001.
    Patience is a virtue and a good cylinder will turn up before you know it?
  17. Shawn McNally
    Shawn McNally
    Page, AZ
    Got her up and running! Over one month I was waiting on the piston! Now I need an air filter!
    w8ye and DexterDay like this.
  18. MasterMech
    Gotta love Dolmar for that.... ;) :mad:
  19. Shawn McNally
    Shawn McNally
    Page, AZ
    Will this model fit my saw? It looks identical.
    SACHS/DOLMAR NYLON AIR FILTER PART#114173031 - NEW - USED ON 114/117/119 MODELS
    It is on ebay.
