  1. bogieb
    Headed in to my night job this morning (long story and not interesting). Worked out well since the dump is closed for Veteran's Day, so I may, or may not, have thrown a pellet bag full of used cat litter and trash in their dumpster :whistle:.
    Got home and complete two loads of laundry and mowed leaves for almost an hour. Cleaned up the rest of the lily stalks, watered indoor plants and cleaned both stoves. I didn't do a full clean, everything but the exhaust as those should be good until next cleaning. I definitely left the P43 until the last minute as far as the ash pan goes.
    October Glory maple is confused and thinks it is a November Glory - picture taken today. Last maple to have any leaves at all.
  2. gbreda
    gbreda
    NH
    Finished up a day of outside work. Was actually nice in the sun as long as you kept moving.
    Took out the sn*blower, got it running and put it in the garage. MC swapped places and went in the shed for its winter nap.
    Few hours of yard cleanup with the lawnmower as well as taking down some large broken limbs that were hung up on other trees from the wind storm a week ago-some of those would have done major bodily damage if they hit anyone that didnt know they were there.
    Still need a day with the chainsaw to clean up a lot of down or broken stuff that is leaning on other trees plus need to cut up 1 large tree that fell but all of that may be a spring thing.
    imacman, ivanhoe, jtakeman and 8 others like this.
  3. will711
    will711
    Pocono Mts.
    576CA889-2986-4138-84AE-0440470FB568.jpeg 6B19E84F-1255-4BBE-BC1B-63FFE5946C88.jpeg I blew leaves and cut down this old plum that hurricane Sandy took half of it was dying
    savemoney, imacman, ivanhoe and 9 others like this.
  4. gbreda
    gbreda
    NH
    The snowblower didnt want to start at first, but finally got it running then it just stopped after about 30 seconds and woudnt start. Re checked everything, pulled the plug and all looked fine. After 30-40 minutes of this and that I saw the fuel valve was off :doh:. I didnt recheck that because I knew I had turned it on earlier.
    It was definitely on as that was the first thing I checked when it didnt start in the beginning but I was flipping any thing I could to get it re-started after it ran a bit but I must have left it in the off position while playing with things. The 30 second run was all that was in the bowl.
    Soooo, first I leave the plug in the intake tube of the stove 2 weeks ago and now this. Is 54 when CRS starts setting in? :emb:
    savemoney, imacman, ivanhoe and 10 others like this.
  5. gbreda
    gbreda
    NH
    Nice!!- like the Husky boy toys, same as we use here on both of those but I only have a 240 saw-there are times I could use a 345 around here
    savemoney, imacman, ivanhoe and 6 others like this.
  6. will711
    will711
    Pocono Mts.
    Me too tomorrow it's mow for the last time and fire up the white chit blower .
    savemoney, imacman, ivanhoe and 8 others like this.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    :whistle:
  8. will711
    will711
    Pocono Mts.
    I think it started at birth for me :smoke:
  9. gbreda
    gbreda
    NH
    I know I helped it along for many years
  10. will711
    will711
    Pocono Mts.
    You and me both brother :whistle:
    imacman, ivanhoe, jtakeman and 5 others like this.
  11. smoke show
    smoke show
    Pittsfield, Wi
    I'm hoping to live to 54.
    eatonpcat, imacman, ivanhoe and 9 others like this.
  12. slvrblkk
    slvrblkk
    Northampton, PA
    There is NO WAY I make it to that
  13. slvrblkk
    slvrblkk
    Northampton, PA
    Me too :smoke:
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    me too,thats really old.
  15. smoke show
    smoke show
    Pittsfield, Wi
    How many years ago was 54?
    imacman, ivanhoe, jtakeman and 6 others like this.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It is usually well advanced by that age. A good clue you have is when you only drink half of your first mug of coffee of the day.
    savemoney, imacman, ivanhoe and 7 others like this.
  17. will711
    will711
    Pocono Mts.
    This is a trick ?? right :whistle:
    imacman, ivanhoe, jtakeman and 7 others like this.
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Just a few years.
    imacman, ivanhoe, jtakeman and 4 others like this.
  19. smoke show
    smoke show
    Pittsfield, Wi
    I can kill a pot by 9am.
    imacman, ivanhoe, jtakeman and 9 others like this.
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Then you haven't got CRS yet.
    smoke show, imacman, ivanhoe and 7 others like this.
