Englander 25-PDVC weird Problem!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Nov 10, 2017.
  1. don2222
    don2222
    Salem NH
    Hello
    I am working on this stove. After replacing a few parts I put in a new Igniter and it started fine. So I thought it was working fine. The next time I started the stove, it would not fire up and the tip of the new igniter I put it was not warm! So I put in another igniter and before my eyes, the igniter almost lit the pellets and then blew out! Two bad igniters? Very Strange so I put in a 3rd igniter that was a different brand and then after less than a minute click the GFCI outlet tripped a ground fault! That means a hot lead is leaking to ground! So I looked at the wiring and I saw the problem! Pic 4 - shows the problem
    So The shorted to ground Purple wire caused the igniter to burn out?
    Pic 1 - 3 rd igniter that tripped GFCI outlet
    Pic 2 - Auger motors
    Pic 3 - tripped GFI outlet
    Pic 4 - close up of 2 purple wires going to the lower auger motor shows one bare purple wire!
    CleanFire, ivanhoe and IHATEPROPANE like this.
  2. subsailor
    subsailor
    Winthrop, Maine
    There aren't any pics.
  3. don2222
    don2222
    Salem NH
    Just finished uploading them
  4. don2222
    don2222
    Salem NH
    Hello
    So I disconnected the igniter and the stove ran for more than 1 min so I put the 3rd igniter on the test bench.
    Well the 3rd new igniter seems to be damaged and not working at the tip.
    I put in a 4th igniter and the GFI still tripped. Therefore I plugged the stove into a non GFCI outlet in my shop and a little after 5 minutes it fired up nice!
    Watching FX with a La Fin DuMonde! Lol
    CleanFire, ivanhoe, ChandlerR and 2 others like this.
  5. PelletHound
    PelletHound
    SE Ma.
    Drink a six pack of those and you won't remember your name.:drunk:
    slvrblkk, CleanFire, jtakeman and 3 others like this.
  6. IHATEPROPANE
    IHATEPROPANE
    I think you could fit another stove in there!!
  7. ivanhoe
    ivanhoe
    Northern Ontario
    So true :drunk:
  8. CleanFire
    CleanFire
    Probably - resistance-based devices don't handle (over-current) shorting well, melts the internal winding pretty quick.
  9. don2222
    don2222
    Salem NH
    Yes, I thought the igniter was defective but not 3 igniters!!
    The auger motor wire must have touched the hot exhaust housing causing the insulation to melt!
    ivanhoe, slvrblkk, CleanFire and 2 others like this.
  10. CleanFire
    CleanFire
    Thanks for the post & pics don2222 - going to re-check -> visually verify -all- the wiring on the 25-PDVC here today - much appreciated. :yes: ( I'll stay away from the Beer until later. ) :D
    ivanhoe, don2222, slvrblkk and 2 others like this.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Well, don't we got a smarty pants here!!! :rofl: :lol: Just messin' with you brother!!!
  12. don2222
    don2222
    Salem NH
    When you check your wires, have some wire ties handy and tie up anything with too much slack that could come in contact with and hot metal. Good Luck
  13. CleanFire
    CleanFire
    Beer helps to enhance my thinking. :thumbs: ... A famous Sig I've read "somewhere". :p
    :cheers:
  14. CleanFire
    CleanFire
    Thanks Don! I'm gonna need it. :picard:
    :coldone:
  15. slvrblkk
    slvrblkk
    Northampton, PA
    Hmmm, I wonder where? :rofl: :lol:
