  1. Gasifier
    27 here and I'm still burning Pine. I'll be burning all this White Pine up for the next two weeks at least.
  2. FatBoy85
    FatBoy85
    Washington State
    35° and tended to the fire at 430 this morning, by then it was around 30°. Loaded old apple wood ontop of birch coals. Last night’s fire was VERY nice! Had a window open and small smells of the smoke ever so slightly drafting in.
  3. Sean
    Sean
    -20c/-4f this morning under clear skies. Ill be loading the stove with doug fir shortly before heading out in the world.
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    49f right now outside, finally feels like fall, 74f inside so when the kids get home they can do homework by the stove
    greendohn, Sean, Rope and 3 others like this.
  5. Backwoods Savage
    Was 28 this morning when I had to leave at 7:00. A bit nippy.
    bear 1998, greendohn, Sean and 5 others like this.
  6. saskwoodburner
    saskwoodburner
    Sitting at -10 C (14 F) but -17 C with the wind. Poplar and a big stick of pine for a night snack, and poplar and a chunk of larch for breakfast.
    bear 1998, greendohn, Sean and 4 others like this.
  7. Gasifier
    The sun has come out pretty strong today. About 37 or so early this afternoon.
    thewoodlands The water is pretty high today on the Oswegatchie. Not over the wall, but it is really moving fast. To the left of the dam it is over the Peninsula this side of the old pump house. It's pretty high when it's over that. I don't know if I caught it at peak from all that rain or not.
  8. JustWood
    JustWood Guest
    43
    Been having fires nights below 40 which have been few. Don't refill in morning . Close the door between the lower 2 levels of the house and run the 'pane when I'm gone during the day. Work is slowing to a pace where I can tend the stove consistently . The truck Nazis have been running around my area all morning. Parked the truck and called it a day . Filled all the indoor racks and fired up. Looking at the 'cast I will prolly be burning 24/7 here on out. Got a mix of about all the more dense hardwoods for the shoulder stove . Wood is about 4-5 years seasoned, bark free and unidentifiable . I can't believe the extended summer we have had. It's just turned colder in the last 10 days. Looks like I'll be hanging out here a little more .
  9. yooperdave
    Mid 20's right now with strong sunshine once again. But man oh man, is there a chill in the air.
    Clear skies tonight, at least teens for lows....then singles for lows after that.
    The ponds and slow streams are turning hard. Hope the highways stay bare, don't mind driving in these conditions!
  10. billb3
    Pine fire.
    Cleaned out chimneys this afternoon and having a test fire / first fire of the season .
    46ºF outside.
    Supposed to be cold by the end of the week so getting things going and ready.
    Door gasket is coming unglued and sagging a tiny bit at the top so will have to get some cement and hope it holds it back in place before it gets worse. IMG_0678.JPG
    4 splits of pine
    then 2 more splits of pine
    then 2 splits of white oak
    Hey, why not !?
  11. Locust Post
    44 outside, just getting a few pieces of cherry going for the evening......sounds like something thewoodlands would have said........:cool:
  12. bear 1998
    bear 1998
    S.C.Pa
    32 here...came home to sleet on the driveway n vehicles n trailer...72 inside w a door open...might be the beer causin my temp to be up..lol
  13. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Mid 30s for highs and lows in the low 20s. Been loading the Ideal Steel once a day in the evenings having it carry the cold nights. Close it down in the AM to save coals for the reload in the PM. Letting the NG get the house back up to temp in the evening (being its so cheap). Conserve some wood for the frigid days!
  14. thewoodlands
    thewoodlands
    I think this will be the first year that we don't have any Cherry.
  15. billb3
  16. FatBoy85
    FatBoy85
    Washington State
    Someone say Cherry?
    Sean, Rope and Thor like this.
  17. FatBoy85
    FatBoy85
    Washington State
    o_O For as long as Ive been on here while still winter for you, it was just that stuff so often...
    Rope, Thor and thewoodlands like this.
  18. amateur cutter
    Somebody put that on the FHC Calendar. thewoodlands with no Cherry! The world has tilted off kilter. :jaw:
    greendohn, Sean, yooperdave and 3 others like this.
  19. amateur cutter
    How far is it to your place Zap? I've got some 40" Cherry logs I could drop to you, make you feel more like yourself again.
  20. thewoodlands
    thewoodlands
    We have three more cherry trees that are down that I'll need to get in the spring. We'll have about two face cord of cherry ready for next year.
