#10 gear oil equivalent?
Discussion in 'Chainsaws and Power Equipment' started by fishingpol, Nov 5, 2017.
  1. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I picked up a mid 1940's Delta scroll saw. A big, heavy bugger with a 24" throat. I'm in the process of cleaning it up and I want to change the gear oil in the sump. I've done some reading and a similar model takes #10 gear oil. Does anyone know the quick and dirty for a on the shelf equivalent?
    I'm trying to make sure the major components work before cleaning it up and building a base for it. It is going to take some real estate in the shop, but it should be worth it. It looks like it was removed from a basement in a clean out. Just dust covered and a pretty new belt. The motor looks original and works quietly and well with little vibration. A bit of the gear oil spilled prior to me getting it so I would like to start fresh.
    I appreciate any help on this.
  2. Bret Hart
    Bret Hart
    Central NY
    Got a text into a buddy that's some kinda certified lubrication specialist. Should have an answer soon.
    clemsonfor and SKEETER McCLUSKEY like this.
  3. fishingpol
    fishingpol
    Thank you.:yes:
    I have to get this thing off the floor and onto a bench to really get into it. Too many projects.:headbang:
  4. Bret Hart
    Bret Hart
    Central NY
    #10 is an ISO grade system number. See chart in link below.
    VISCOSITY- SAE, ISO or AGMA? | Doolittle Oil
    On the chart #10 ISO is roughly an SAE 0W engine oil or SAE 30 to 40 weight gear oil which you may not find.
    SAE 75W gear oil should be fine.
    clemsonfor and fishingpol like this.
  5. fishingpol
    fishingpol
    Thanks again Bret. That chart is a big help. I'm trying to get things right for this restoration.
    clemsonfor and Bret Hart like this.
