Runs better after cleaning
Discussion in 'Modern EPA Stoves and Fireplaces' started by Suburban wood snob, Nov 5, 2017.
  1. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Has anyone else noticed that your stove or insert seems to work better after you clean it? I did the sweeping yesterday... This morning I took out the fire bricks and baffle, and removed the secondary tubes. Scraped the inside surfaces with a putty knife and shoveled it out. Tubes had deposits on the holes, scrubbed with scratch pad, looks clean now. When I did this the last time I was amazed at how much better it produced secondary flames and the fan came on earlier... Almost like the heat was being insulated from escaping before. I can't wait to see if it happens tonight again... Assuming it cools off, been pretty warm so far.
    Anyway, curious if others noticed this, or it's just my own weird obsession with the stove being cleaned good
    Chvymn99, wildwest, Gark and 3 others like this.
  2. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Poops. Posted in wrong forum. Sorry moderator. Please move to epa land.
  3. Grizzly Adam
    Grizzly Adam Guest
  4. Suburban wood snob
    Suburban wood snob
    Milwaukee
  5. Backwoods Savage
    My car even seems to run much better after a washing.
    We don't have a tube stove but it makes sense that cleaning the tubes would make a difference.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Absolutely. My current stove had a chunk of charcoal blocking one of the primary air holes on the dog house inside the firebox.
    The secondary combustion intake on my last stove was partial blocked by some crumbled stove cement and cobwebs from sitting unused over the summer.
    I resealed the inner stove plates on my Castine this year as the cement cracked and lost its' seal. Secondaries are great now.
  7. saskwoodburner
    saskwoodburner
    I always feel better after cleaning the chimney and stove. Can't say it runs any better though. I suppose smooth surfaces would allow the air movement to be improved?
  8. Gark
    Gark
    SW Michigan
    I always thought we saw improved burn after a cleaning too. Maybe the removed gunk sort of insulated the firebox heat from the stove body somehow.
  9. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Nice and cold tonight and sure enough it's running really well after the cleaning.
    papadave likes this.
  10. HDRock
    I think mine does run a little better after cleaning.
    I take all the tubes and the bricks out of the top,, scrape the area above the bricks , vacuum it out real good, I run a brush through all the tubes and clean the holes out
    Camber and papadave like this.
  11. Unhdsm
    Unhdsm
    Bradford, Vermont
    There’s an old saying that “a clean car always runs better”.
