Utah juniper (cedar)
Discussion in 'The Wood Pile' started by Shawn McNally, Mar 6, 2014.
  1. Shawn McNally
    Shawn McNally
    Page, AZ
    I have heard from a person that I trust a lot that you can burn Utah juniper ( called cedar here locally) green cut! Anybody know this to be true?
    If that is not true what is the drying time you think would be adequate? Our summer days are near 100 daily and humidity is in the teens!
  2. Got Wood?
    Got Wood?
    Amarillo, TX
    Anything will burn if the fire is hot enough. However, if you want it to burn better and cleaner and provide better heat, then it needs to dry. I'm just guessing that as a softwood its gonna be 8 -18 months
  3. stuckinthemuck
    stuckinthemuck
    If you cut/split/stack it now, it should be ready to burn by the fall. Mother nature might argue the point that it'll burn right now.o_O Sure is some gnarly stuff.. Good luck with the splitting.
    Generally grows along with Pinyon Pine in the Pinyon Juniper scrub lands that dot the intermountain west.. Land managers often want to get rid of it along with the sage brush to restore grasslands for grazing. Adds to the fuel load for wild fires. I think it'll burn fine in your stove, but that's just based on how I've seen it burn after being hit by lightning on a 100 degree day at 4% relative humidity and 40 knot winds.:MM:
    http://cpluhna.nau.edu/Biota/pinyon-juniper.htm
    HoneyFuzz and Shawn McNally like this.
  4. Wood Duck
    Wood Duck
    Fresh cut oak will burn too, but it burns a let easier and hotter if you let it dry first. I think one summer out there should be enough to have it pretty well seasoned.
  5. Shawn McNally
    Shawn McNally
    Page, AZ
    Thanks. The stuff splits green easy and you are on the Money about land managers . We can cut it green as part of a clearing project for wildlife. BLM PJ clearing project!
  6. stuckinthemuck
    stuckinthemuck
    Glad to hear that you're able to cut it for free. They couldn't hire enough people a while back for the fuels reduction projects that they were doing in the southwest. More people like you would prove beneficial to the project. Got to burn 800 acres of sage and PJ back in the day as part of a prescribed fire.. What a rush to set that on fire!!!!... You're not only getting some BTU's, you're providing a public service in reducing fire danger... Good work!!!
    mdavlee likes this.
  7. Shawn McNally
    Shawn McNally
    Page, AZ
    Not totally free. 25 for 5
  8. Shawn McNally
    Shawn McNally
    Page, AZ
  9. nate
    nate Banned
    Palmer, AK
    And they complain that wood stoves are killing the earth. That 800 acres burned probably pumped more crap in the air in a few days than a few winters of burning for all woodburners in the state!
    Backwoods Savage and HoneyFuzz like this.
  10. stuckinthemuck
    stuckinthemuck
    Nate, I can't and won't argue with that.. Bottom line is that PJ is going to burn one way or another. Allowing people to c/s/s and run it through the stove means that each cord of wood will put out FAR LESS pollution (by having a hotter fire and more complete burn) than it would in a wildfire. Try getting that message through to a politician!!
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Always...always...always....cut , split , dry your wood !! Good luck :)
    Backwoods Savage and mdavlee like this.
  12. mdavlee
    mdavlee
    I would think small splits would dry pretty quick in your area. Should be ready by winter next year.
    HoneyFuzz likes this.
  13. stuckinthemuck
    stuckinthemuck
    Easier said than done....:whistle:
    HoneyFuzz and mdavlee like this.
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Thats more of a kiln dried process :)
  15. Backwoods Savage
    Welcome to the forum Shawn.
    Of course you can burn it now but you'll be a whole lot happier letting it dry for a year. Six months in a pinch.
    Someone stated you can burn oak freshly cut and that is true. Even cottonwood. I remember one woods we cut for a fellow and we cut only beech and cottonwood. We had a fire going every day to burn the slabs as they were cut. No problem once you got the fire going. However, that was outdoors and not in a stove.
