Alaska firewood, 2017
Discussion in 'The Wood Pile' started by bogydave, Oct 19, 2017.
  1. grandgourmand
    grandgourmand
    Ontario
    Looks like you forgot to split one piece in the bottom right corner. Get the splitter out!
    blacktail and HDRock like this.
  2. bogydave
    Well
    Forgot , kinda
    A nasty crotch that would make uglies
    Will use it as a paper weight :)
    campinspecter, Chvymn99 and HDRock like this.
  3. bogydave
    31°, Foggy
    Dark, cold , dreary day so far
    But still seeing green grass :)
  4. bogydave
    6 cord stacked
    About another 1/2 + to go
    32° & fog
    3B626644-1A81-4588-B0D9-F4B153820568.jpeg 1341D61D-C973-4B41-8D12-6F9C73A1CB6E.jpeg
    FatBoy85, Stephiedoll, milleo and 7 others like this.
  5. HDRock
    :yes::axe::tree::stacke::stacke:
    FatBoy85 and Chvymn99 like this.
  6. bogydave
    About 8 hrs of daylight now
    Barely light at the end of the tunnel
    But think I’ll make it :)
    Daylight savings not gonna help much
    Put the splitter away/ran it out of gas
    Uglies stacked
    Steamed some of the splitter tailings:
  7. Backwoods Savage
    Yes, I do. Think I have 2 of them. Perhaps I should send one to you?
    campinspecter likes this.
  8. bogydave
    24° @ sunrise
  9. HDRock
  10. bogydave
    It is good to see the sunshine here, it’s
    been scarce this Fall
    We’re gradually transitioning into winter .
    Not getting much heat from the sun now
    Gearing up to go stack wood :shiver:
    HDRock likes this.
  11. yooperdave
    Thanks, I'll try that for an excuse here!
    HDRock likes this.
  12. bogydave
    11:45 , sun angle pretty low
    But sure is nice to see it :) 1E771B9D-C390-4496-9BC5-31425FCF6003.jpeg
    FatBoy85, Stephiedoll, milleo and 5 others like this.
  13. bogydave
    Sun warm enough to melt the frost
    No sun on the N side of the stack
    milleo, campinspecter, Hammy and 4 others like this.
  14. bogydave
    So much for the heat from the sun
    Fog rolling in
  15. HDRock
    Big time fog :binoculars:
  16. yooperdave
    If you hadn't cut the lawn, you'd be able to say "fog in hay" :whistle:
  17. bogydave
  18. billb3
    Those are some pretty long shadows for 11:45 AM
    Empty pallets means one more trip for some more logs or that's enough to replace what you need.
  19. bogydave
    Needed about 6, measures to about 6-1/2 , but loosely stacked & will shrink a bit
    Calling
    it
    DONE
    :yes:
  20. HDRock
    Done and done :thumbs:
    Nice work Dave :saw::tree: :quad::tree::axe::axe::stacke::stacke::stacke::stacke:
    Wood train lookin sweet dude :yes:
