Earth Stove putting smoke out the chimney
Discussion in 'The Wood Pile' started by bang, Oct 30, 2017.
  1. bang
    bang
    South central Indiana
    Put the old Earth Stove in place and fired it up in the shop, the wife was worried about the cats getting cold. That thing is a wood hog but puts heat in the shop and a lot up the chimney. I'll probably let it burn out after tomorrow as it looks like warm weather is headed this way
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    Does it smoke for the entire burn or just when you start the fire
  3. bang
    bang
    smokes always
    Flatlander Pete likes this.
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    Are you getting enough draft
  5. bang
    bang
    it acts like the draft is weak but its 6" straight up and goes into 2 wall insulated and exits about 4' above the roof crest. it burns wood so fast it must be drafting but it smokes out the door when i open it
  6. Erik B
    Erik B
    Western Wisconsin
    bang I am using an Earth Stove insert and I find it works best to either open the draft fully or open the door slowly to keep smoke from coming into the house. As long as I keep a hot fire going, there is minimal smoke coming out of the chimney except at start up.
  7. billb3
    There's a few people here ( or that have been here) that have or have had one.
    Earth Stove
  8. bang
    bang
    I bought it a few years ago and didn't realize it had been "redesigned". I'm pretty sure it was an insert and someone welded up the rear exit and cut and welded a 6" id steel pipe on top. It just occurred to me that all other Earth Stoves I've seen were 8" so this one may never work properly but it's the small version with 8 scallops.
  9. HDRock
    Before you open the door , open the stovepipe damper and air control all the way, your sure going to get smoke if you don't
    You do have a stovepipe damper on it right ?
    Flatlander Pete and EnglishBob like this.
  10. Boomstick
    Boomstick Banned
    Saratoga county ny
    Mine has a 7 inch collar. Ran it on a 6 inch and it did really well.
    Do you have pictures to verify?
    Flatlander Pete and bang like this.
  11. yooperdave
    Yeah, opening the door slowly will defeat the vacuum type draft that opening the door creates...pulling smoke out with it, right? :yes:
    Flatlander Pete, bang and Erik B like this.
  12. bang
    bang
    Yes, I do open the door slowly and it has a damper
    Flatlander Pete and yooperdave like this.
  13. bang
    bang
    I'll get some pics this evening
  14. oldspark
    oldspark
    NW Iowa
    What are you running for flue temps?
  15. bang
    bang
    I don't have a thermometer on the flue but I can check with a gun. Fires are out now and I picked up a "new" tractor that I'm getting figured out serviced and generally playing with so I haven't got around to getting pics of the stove setup.
  16. bang
    bang
    I've been slacking and waited until now to check out the Earth stove in the shop. I determined the rod in the damper was slipping causing the draft issue.
    I tried to straighten the rod but it's still slipping so I'll get a new damper this afternoon.
    The photo is what I think is a plate welded over a rear exhaust possibly for an insert, but the control in the rear makes that theory unlikely.
