Chain sprocket rims
Discussion in 'Chainsaws and Power Equipment' started by blacksmithden, Oct 30, 2017.
  1. blacksmithden
    blacksmithden
    Alberta Canada
    I've never owned a saw that used sprocket rims before. How long do these things last ? Are they something your average home owner cutting 3 or 4 cords a year would replace once a day...once a cord...once a year...never ? Just how much of a consumable are they ? Also, are the splines a fairly standard size...22mm ? Also, can you just switch them from say 3/8 to 404 chain and use the same clutch drum ? Edge-ju-meh-kate me please. :)
  2. bogydave
    J. Dirt, blacksmith and papadave like this.
  3. Fifelaker
    Fifelaker
    Fife Lake Mi.
    They last quite awhile, it depends on a few things. Chain tension, oiler, dull chain to name a few. You can change them out for pitch and number of teeth. You do have to match them to the spline on the clutch drum.
  4. RCBS
    Buy a couple and stash them in your saw box. Having a new one on-hand will give you an idea of the wear on your current sprocket by comparison.
    blacksmith and Ronaldo like this.
  5. The Wood Wolverine
    I average 5/6 cord per season and I only need to change them every 2/3 seasons or so. Probably could get away with more but I like to keep them kinda fresh. It’s a cheap maint item. Splines are not all the same size, make sure you have your saw info ready when you order.
    Here's what they look like worn:
    Good news is that just the rim needs replaced, not the hole spur/drum.
    Will C, OldJack, Horkn and 3 others like this.
  6. blacksmithden
    blacksmithden
    Alberta Canada
    Thanks for the responses guys. I saw some on ebay for $2.00 a piece, but no reference to which saw they fit....just that they have 7 splines. Ive ordered a new Oregon drum for my Stihl 051 project saw and it has 1 sprocket on it for 404 chain. I just wanted to have a spare for that, as well as a couple for 3/8 chain just in case I want / need to change it out someday. If the spline sizes are all different then I guess this is something Id better walk into the dealer for, rather than hoping something off ebay fits.
    blacksmith likes this.
  7. cus_deluxe
    cus_deluxe
    Northern Michigan
    The cheapy ebay ones are a crap shoot, heard from guys that theyve had em show up way out of round, or just made of really poor quality steel, so they dont last the way they should. Supposed to replace the rim every other chain or so i think?
    94BULLITT likes this.
  8. OldJack
    OldJack
    Saskatchewan, Canada
  9. 94BULLITT
    94BULLITT
    Frederick County, VA
    Yeah, Stihl says something like. I could not find it on their site. I know it is in the manual. They also say replace the bar every 4 or 5 chains or something like that.
  10. 94BULLITT
    94BULLITT
    I just stumbled upon it looking for something else. Stihl says 4 chains, 2 sprockets, 1 bar.
    cus_deluxe, Horkn and blacksmithden like this.
  11. huskihl
    huskihl
    I run a boatload of those GB rims from LCS. Nothing wrong with them at all. Great selection too. Just gotta order quite a bit of stuff to make shipping worthwhile
  12. J. Dirt
    J. Dirt
    While we are on the subject of drums and rims is there really a big chain speed difference going from a 7 to an 8 tooth?:saw:
    Rope, Horkn, Nixon and 2 others like this.
  13. The Wood Wolverine
    Yep. But it translates into the saw's rpm, typically lowering it too much if there is not enough power to pull @ the higher speed.
    Rope, Horkn, J. Dirt and 1 other person like this.
  14. Nixon
    Nixon
    West Sunbury,Pa .
    What WW said . You’ll get speed , but lose torque . So, you need a fairly snotty saw to run 8t ,or run a fairly short bar for the saw ,or have a fairly light touch when operating . YMMV .
  15. J. Dirt
    J. Dirt
    Just picked up a 6400 Dolmar and I think I’m going to run a 20” on it and maybe do some tinkering :dremel: as well. Its totally stock right now and I haven’t had a chance to cut with it yet to even know how it is power wise.
    May be a candidate for an 8 pin?
    Rope and blacksmith like this.
  16. 94BULLITT
    94BULLITT
    It won't run an 8. You need a saw up around 7hp to run an 8.
    Sent from my SM-G950U using Tapatalk
    cus_deluxe, blacksmith and J. Dirt like this.
  17. J. Dirt
    J. Dirt
    Wow! Really does make a big difference then:eek:
  18. concretegrazer
    concretegrazer
    Southwest MO
    I have run a 8 pin with a 20" bar on a stock 440 for years . It handles it fine.
  19. concretegrazer
    concretegrazer
    Southwest MO
  20. Horkn
    J. Dirt likes this.
