Thinking about investing in a splitter...opinions on this
Discussion in 'The Wood Pile' started by Rangerbait, Oct 28, 2017.
  1. Gasifier
    Those DHT splitters look good. And good price.
    Or you could go with something like this. Watch your hands though.o_O
  2. HDRock
    Guy has guts I'll give him that
  3. TurboDiesel
    :yes:
    The rounds that "tipped" the machine up was when it took two of us to lift the rounds because I could no longer lift them myself. Tipping is not common problem, I only mentioned it because Rangerbait said in another thread he could load big rounds with the loader bucket.
    Most people aren't lifting 20+ oak rounds on to a horizontal splitter. I usually go vertical before 20"
  4. Leadfarmer
    Leadfarmer
    SC pa
    Check out the vids on you tube. Super split and split second are prolly the most expensive but made here in the USA. I think split second can be towed not so much for super split, I'm talking over the road here. There are a bunch of Chinese units here also. The one I have I believe to be a black diamond not sure though cause of no decals. Found it on evilbay for 800 bucks and thought I could a ford to loose that if it we junk I just couldn't believe the vids of how fast they split, I was wrong. I figured it wouldn't split tough stuff so I kept my 32 ton hydro just in case but haven't used it since. The fastest we have split with it was 1 1/2 cord in 22 minutes with 4 guys bringing wood an taking it away. They are really that fast. I have prolly 30 cords through it now not sure how long it will last but have had zero troubles with it so far. Real gnarly chucks my take a couple hits but will cut right through. I don't think I got into any elm yet or apple like @woodwolverine . I would definitely recommend checking them out. Good luck Buddy.
    Sent from my SM-G900V using Tapatalk
  5. MikeyB
    MikeyB
    Long Island NY
    Check out the YardMax line of splitters. They come either full or half beam and come with a lot of extras that other brands charge extra for, have seen good reviews on these splitters.
    I have a 7 ton Boss electric. When it comes time for a need to go bigger I might stick with the Boss line or try a YardMax half beam. But some of the Kinetics look cool as well, a lot of different brands to choose from.
    Or maybe one of the electric models like a 16 ton Ram splitter or the Swisher 22 ton electric.
  6. FatBoy85
    FatBoy85
    Washington State
    Just don’t go making your own....
    This one might get the job done but free fingers anyone??
    I have the 22 ton DHT splitter. Got it on sale for about 850 but after tax it was close to 1000. It was originally about 1100 at Lowe’s.
  7. Horkn
    Yep. The old didier splitter we have at the house is nowhere near 20 tons ( maybe 14?) and it splits everything, even a lot of stringy elm. No issues with anything really. The lighter physical weight will be appreciated when you have to lift it into a truck or onto a trailer. We also have an mtd 21 ton horizontal/ vertical splitter that we keep up north.
    You want as quick of a cycle time as you can get.
    Kohler motors are very good, easy to start. Honda's are too, but are typically way overpriced.
    I'd wait for the tsc or whoever has the black Friday sale for 850 for the 22 ton.
  8. Horkn
    I have an apple tree that I have in rounds right now. I haven't split much apple in the past, and when I did, it was dry, very dry. I'll let you know how the old didier splitter does on it. Now that didier it's like 14 Ton, and is around 40 yrs old. The old original Briggs 5hp would stall on elm and other gnarly hard to split stuff. But I attribute most of the stalling to the old weak low compression motor. I put a 6.5 HP chonda predator motor on it last winter, and I couldn't stall it. I processed 5 cords of wood last winter and most on the predator motor. There was 2 cord of elm in that amount. The honey locust was tougher to split than the elm. The new predator motor couldn't be stalled.
    To me, it's more about the power of the motor than the tonnage of the hydraulics. These gear pumps go into low gear when they need to.
  9. oldspark
    oldspark
    NW Iowa
    As I age I find slower can be safer.
    Another vote for the 22 ton Speeco, splits everything I have run through it, I split wood for 30 years by hand (young, dumb, and stupid:D), and never going back.
  10. RCBS
    Got a great deal on a Forest King 30 2 years ago at Menard's on Black Friday. Just over $800 out the door. If you are gonna buy, black Friday is the time.
  11. Warner
    On big thing for me is the height of the splitter, most newer splitters are taller but I have used some that are quite low. Meaning you would be hunched over when working not fun.
    I too have the huskee 22 ton and haven't found a piece of wood that it won't split. And I don't find myself standing around waiting for it to cycle. Probably split 25 or so cord with it no issues. The ad on "table" is a must for me.
    I haven't had the chance to use a Kenetic splitter.
  12. Backwoods Savage
    I have to respectfully disagree with you on this one. Our 20 ton will take care of it very well. It has also only a 5 hp motor so uses very little gas. Also, as Tim stated, it is easier to move around. I really see no reason to go bigger than this 20 ton.
    Eric VW, HDRock, Chvymn99 and 2 others like this.
  13. Backwoods Savage
    I've written about splitters many times and my opinions have not changed. First off, our splitter is coming up on 30 years of use and splitting over 300 cord of wood with much of that being elm. We've split not only our own wood but wood for many others plus we have loaned our splitter out to friends and neighbors. Recently we loaned to a neighbor who had splitter that you could only use horizontally and he had some big stuff that he could not lift. In addition, his wife actually does most of the splitting. So they used ours, which, like any good splitter will stand upright and split the right way, vertically, just like you split by hand. They got the job done and done much faster and were also surprised at the speed and power of our splitter; a 20 ton model with a 5 hp motor.
    My feelings.
    1. Large tonnage is okay but mostly built for those who always think that bigger is better. Is it necessary? Splitting wood I rarely think so.
    2. Cycle time is usually immaterial. Highly over rated. After all, if you know what you are doing, you rarely use that entire length so even a splitter that might have a 15 second cycle time could very well cycle at 8 seconds or less.
    3. Large motors are over rated and simply use a lot more gas to run them. A good pump is worth much more.
    4. I like the 2 stage pump where if you get the really gnarly ones or wood with crotches, the slower stage gives more power to get the job done.
    5. Once again, vertical splitting ability is a must; just like you do by hand; just like God intended.
    6. I really can see no reason to stand and split, but standing still is difficult for my back. But even more so, if you stand to split, most times, unless you are unloading from a truck or trailer, you have to bend over to pick up the log to put onto the splitter. If you sit, you simply roll the log onto the splitter and save your back.
    7. Smaller splitters use less gas and oil and sometimes are much more quiet.
    There's a little more but I'll stop here.
  14. The Wood Wolverine
    I came to my senses Dennis! lol That monster elm I worked through would have laughed at a 20T. I only had a weekend with a 2xT years ago before I found my current 34. It did just fine splitting what I threw at it. My train of thought is instinctively "how would it do with the apple". I'm sure it would, just not as fast as my larger unit. Which is why I initially mentioned the kinetic.
  15. Backwoods Savage
    One of these days I will have to make a list of any videos I've posted on youtube but right now can't find any...
    NH mountain man and Eric VW like this.
  16. Backwoods Savage
    It is difficult to make a complete comparison unless the splitter might be working side by side. As for the kinetic, I really do not like any I've seen.
  17. The Wood Wolverine
    I've watched them at gtg's and I'm sold. Wish I had one, in fact I'd trade in a heartbeat. They're just soo much faster. A lot of times I have to cycle the wedge the whole way to the bottom of it's travel.
    All my experience is with orchard trees which are trimmed to stay low so pickers don't have to go way up a ladder. If your is a yard tree, it may not have the gnarly limb sections I get. Plus I usually split wet, which yields the most amazing aroma!!
  18. Horkn
    Yeah, this tree was a yard tree, but pruned like an orchard tree. It was just cut down. It smelled amazing. But it's pretty gnarly. We'll see how it goes once I get the splitter here.
  19. HDRock
    CountyLine 25-Ton is priced at $899.99 right now at some stores
  20. bogydave
    Well
    You should have Enough info
    Which one you get ?
    Money not the issue
    My choice
    Fast & power
    Timberwolf 6 & with a log lift !
