Hydraulic splitter wedge sharpness?
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Oct 27, 2017.
  1. bogydave
    How sharpe should the wedge on a splitter be?
    I keep mine at a good edge but not sharpe like an ax or hatchet.
    Reasoning is , when I come to limbs in the wood, I want to cut them more than push them into the wood deforming the splits
    IMO
    A sharp wedge will help a lot with stringy wood. It’ll cut instead of push
    All bets are off when splitting “gum” :)
    Just sharpened the hatchet(near knife sharp)
    Touched up the splitter wedge
    Used a flat bastard
    Chvymn99, Rope, Horkn and 3 others like this.
  2. bogydave
    Pouring rain here , 42°
    Tinkering in the shop
    Aired up the tires, checked the oil
    Sharpened the pickaroon too
    Rope, Horkn, papadave and 2 others like this.
  3. HDRock
    I sharpen my splitter wedge once in a while with a file
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    I hit my wedge in the spring and fall
    Horkn, papadave and HDRock like this.
  5. papadave
    Splitter hasn't seen much use lately, but I put a decent edge on the wedge a couple years ago. I like it.
    Horkn and HDRock like this.
  6. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Is that a Fiskars hatchet? How do you sharpen it?
    I use a file to take out the burs, then the Fiskars sharpening tool, but it takes forever to get a sharp edge.
    Rope and Horkn like this.
  7. bogydave
    Yes, Fiskars
    I used a bastard file
    Worked fine
    Not shaving sharp, but would slice a tomato & cut wood
    HDRock, Rope, Horkn and 1 other person like this.
  8. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Bastard file? I'm not fimilare with that? Details please.
    Horkn likes this.
  9. Jon_E
    Jon_E
    Southwestern Vermont
    It’s a file whose mother and father aren’t married.
    underdawgal, basod, MikeInMa and 9 others like this.
  10. Horkn
    Lol.
    I've never heard of one either.
    Now, I split a lot of elm, and it's stringy. I never bother with sharpening the splitter wedge. It seems to work just fine. IDK, maybe I should try the dull wedge first in some elm, then sharpen it and try it on the same elm and make a decision?
    HDRock likes this.
  11. MrWhoopee
    MrWhoopee
    Shingletown, CA
    And we're back to my apprenticeship.
    "The cut of the file refers to how fine its teeth are. They are defined as (from roughest to smoothest): rough, middle, bastard, second cut, smooth, and dead smooth. A single-cut file has one set of parallel teeth while a cross-cut or double-cut file has a second set of cuts forming diamond shaped cutting surfaces"
    Chvymn99, 94BULLITT, basod and 6 others like this.
  12. Backwoods Savage
    We've split well over 300 cord with our splitter but have never touched up the wedge. It works just fine.
    Chvymn99, UncleJoe, OhioStihl and 3 others like this.
  13. bogydave
    I had some stringy birch that the wedge cut thru, some is wood tough
    Figure if it’s cutting (not splitting) sharper helps
    Files:
    thewoodlands, OldJack, MikeyB and 3 others like this.
  14. Backwoods Savage
    If any problems appear I will try touching up the wedge. Yes, I'll get a bastard to do it too.
  15. bogydave
    Yea
    You have pretty good splitting wood .
    Bet it’s rare to have to run the wedge
    all the way down,
    then use a hatchet to finish it off
    I think some birch has some gum genes
    Horkn, HDRock and Rope like this.
  16. UncleJoe
    UncleJoe
    SC Pa
    Yeah I've had my splitter for 10 years and never touched the wedge.
    If it wasn't raining I'd go out and take a pic but I don't think it looks too bad.
    Horkn likes this.
  17. Stinny
    I remember keeping the splitting wedge nice and sharp on a small electric splitter I used inside, years ago. It helped...
    saskwoodburner and Horkn like this.
  18. GrJfer
    GrJfer
    The Woods of Arkansas
    Need to sharpen my wedge, found a couple of nails /spikes in a couple of rounds recently.
    HDRock and Horkn like this.
  19. 94BULLITT
    94BULLITT
    Frederick County, VA
    I don't have a hydraulic splitter but the one on my split second is pretty sharp.
