Another Cheap IS!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Mwalsh9152, Oct 28, 2017.
  1. Mwalsh9152
    Mwalsh9152
    Pelham NH
  2. moresnow
    moresnow
    Wow. Somebody on the fence now, should jump on this one. Great find!
    Backwoods Savage and Locust Post like this.
  3. branchburner
    branchburner
    NH
    Hard to believe that's not been taken after two weeks.
  4. FatBoy85
    FatBoy85
    Washington State
    And the wood doesn’t sound like a bad deal at all. First time burner would do wonderful on their first year with this.
  5. Highbeam
    Highbeam
    Brand new door gasket, puffs of paint on the face, two years old, very low price.... Hmm, I wonder what the story is. So weird that the door hinge is on the right!
    FatBoy85 likes this.
  6. Suburban wood snob
    Suburban wood snob
    Milwaukee
    It's Craigslist... You weren't expecting someone to be completely honest were you?
  7. Unhdsm
    Unhdsm
    Bradford, Vermont
    Thiese observations alone wouldn’t scare me. I’ve been on here preaching to check/replace door gaskets after each year. I needed a new one after 2 years.
    The part that is painted- the gasket sits wide around the opening and the part between the seal and the door gets burned and dirty. I’m about to paint mine in the same place. Probably the paint higher up is where the magnetic thermometer was.
    The hindges seem to be in the same place as both IS’s I’ve had?
    I’d still inspect for cracks or case warpage but otherwise I think that is a killer deal.
  8. Kimberly
    Kimberly
    The Kangaroo State
    That could just be a reversed photo.
  9. Kimberly
    Kimberly
    The Kangaroo State
    Like with anything, a good visual inspection should be done.
  10. Unhdsm
    Unhdsm
    Bradford, Vermont
    Frankly I’m amazed they fit an entire Toyota Tacoma inside the firebox.
    brenndatomu likes this.
  11. Kimberly
    Kimberly
    The Kangaroo State
    It looks as only part of the Tacoma fit; the top and bed is missing.
  12. BDF
    BDF
    The door hinges are on the right on my I.S. They are all like that to my knowledge, Woodstock does not / did not make the door opening side an option.
    Brian
    Highbeam likes this.
  13. papadave
    So, you aren't thinking it's been overfired? The pattern is weird for an overfire, but not for a splotchy paint job.
  14. Unhdsm
    Unhdsm
    Bradford, Vermont
    Not based on just the pics. I do think someone used the wrong paint. I’m painting mine in the same area as soon as I get a chance. Which, admittedly, may not be for quite a while. :)
    papadave likes this.
