Which Hydraulic Oil To Use .
Discussion in 'The DIY Room' started by campinspecter, Oct 23, 2017.
  1. campinspecter
    campinspecter
    Know very little about hydraulic oil other than the woodsplitter uses it .
    There appears to be three grades 32- 46- and 68 , what do these numbers mean ?
    The woodsplitter has a vane pump, which number should be used ?
    Thor, Horkn, milleo and 6 others like this.
  2. brenndatomu
    Probably 32 for you...could go 46 too...68 is a little thick for your climate. That number has to do with how "thick" the oil is.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Good topic, im clueless too. How about thoughts on ATF?
    Horkn, wildwest, RCBS and 1 other person like this.
  4. RCBS
    I'm not real knowledgeable, but here is a chart from Lubriplate.
  5. campinspecter
    campinspecter
    The chart is helpfull.
    Thor, Horkn, RCBS and 1 other person like this.
  6. wildwest
    Who can share about viscosity here?
    I had to use a different one on the newer engine in the Blaze, SAE something? Because of the the very cold temps here. Also, ATF vs gear oil?
    Horkn and bobdog2o02 like this.
  7. Locust Post
    I was just looking into this recently. My Huskee splitter manual suggests 46 but says if working a lot below freezing 32 may work better. Also mentions that ATF can be used. I have a new filter but have not picked up the hyd. Oil yet. I will likely use 46 because most of my slitting is done in the Spring. Rural King has the best price around here but did see our local NAPA had 5 gallons as well for a smidge more.
  8. campinspecter
    campinspecter
    I think your machine uses a gear pump. The Beaver Chomper uses a vane pump so I wonder if the lighter oil would be better for it?
  9. Locust Post
    I would say the lighter would work just fine.
  10. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Most splitters that don't have a manual use commercially available pumps. If you can ID the pump you might find an oil viscosity recommendation based on that. The filters and ram probably won't be sensitive to viscosity.
    Being off a viscosity grade probably doesn't matter much. It's just a pump, filter, and ram with some ring seals. Going from cold to hot is a much bigger viscosity change than one grade to another.
    Horkn, campinspecter and Boomstick like this.
  11. campinspecter
    campinspecter
    Seen your post just after I changed oil , hope 32 works !
    Thor, Horkn and papadave like this.
  12. brenndatomu
    Yeah Horkn is the guy too ask about this...some kind of hydraulic guru he is...;) :yes:
    Horkn and campinspecter like this.
  13. yooperdave
    With the north star splitter that I got, it is OK to use ATF. It is listed in the owners manual and does not affect the warranty (which by now is expired anyway) and was less expensive than regular hydraulic oil. Seems to me it was DEXRON....(c'mon memory....) and about $12 a gallon now?
    Horkn likes this.
  14. brenndatomu
    In doing a little research on this, I came across an article that stated ATF, while technically will work, is an inferior product as a hydraulic oil...good for transmissions, not great for high pressure hydraulic systems.
    Never did find anything definitive on oil for a vane type pump. Seems like maybe there would be more info available if the pump make/model were known...
    Here's what I was reading...http://www.sawyersystemsllc.com/sites/all/themes/sawyer/Guide to Selecting Hydraulic Fluid.pdf
  15. Horkn
    It's really down to the temperatures you'll be using it. Hers a handy dandy chart.
    Most splitters use gear pumps.
  16. Horkn
    Yep, that's about right. Atf works, but it's not as good as a hydraulic fluid.
    campinspecter and brenndatomu like this.
  17. Horkn
    Yep, it's fine. Just but as good as hydro fluid.
    yooperdave and brenndatomu like this.
  18. yooperdave
    Yeah, that's what I've been reading these last few posts. I switched to it because of the cost and the ability to use it in lower temps.
    Now, question is, why is it not as good as hyd fluid? What difference, drawbacks?
  19. brenndatomu
    Page 11 in the link I posted above...
    Horkn and yooperdave like this.
