Tonight’s Outside temps are plumeting! Are you firing up your stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Oct 16, 2017.
  1. don2222
    don2222
    Salem NH
    Hello
    My workshop even though it is well insulated, being at ground level, it has a cement floor and was 65 so I turned the stove on.
    The house being a split entry home is still warm on the 2nd floor living space so far and no stove heat needed but that may change?
    Are you running your stove?
    Are you in ground level 1st floor living space?
    How well insulated is your abode?
    CleanFire, savemoney, BHags and 2 others like this.
  2. subsailor
    subsailor
    Winthrop, Maine
    Already burning here.
    CleanFire, imacman, savemoney and 3 others like this.
  3. jtakeman
    Not yet! Baking is keeping us warm.
    If I do the stats only going to 68 ºF. Paying for collage, So.................... :emptywallet:
  4. subsailor
    subsailor
    Winthrop, Maine
    Has the missus bought into that?
  5. IHATEPROPANE
    IHATEPROPANE
    Thermostat is on
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Sig update time OM.
  7. The Wood Wolverine
    Still holding out here. Calling for a low of 36. I just asked the wife if she wanted a fire and got a no.
  8. IHATEPROPANE
    IHATEPROPANE
    To be fair, the new stove is off. Not needed until we get some of the real cold. So I think i have a little more time before i need to update the sig:D
    CleanFire, imacman and PelletHound like this.
  9. don2222
    don2222
    Salem NH
    Mount Washington was capped in ice this morning!
    See
    Mount Washington summit coated by ice
    Looks like it is going down to 38 Degs here by 7 AM according to News 9 NH weather in Manchester! See attached pic below.
    Nice to have more than 1 Pellet Stove IHP ??
    Does that give you 100K BTUs of nice summery pellet stove heat???
    I have 204K BTUs with my 4 Pellet Stoves.:)
  10. jtakeman
    I'm thinking dummy stat up stairs that says 72, While the hidin one set to 68..............
    I'm likely to get :heidi:
  11. IHATEPROPANE
    IHATEPROPANE
    I used to have over 100k. Now I am at about 70k give or take. One thing I learned having the West Point is I really didn't need the last two settings. Making the extra HP unnecessary.
  12. don2222
    don2222
    Salem NH
    Just connect the dummy stat to an electric heating coil in the wall behind the dummy stat to give it a dummy temperature to be more realistic. :)
    CleanFire and PelletHound like this.
  13. ChandlerR
    ChandlerR
    Seacoast NH
    Fired mine up around 8 tonight. First long burn with the new combustion blower. So far I am very happy. It's on low and it's nice to see a very active flame. Normally I would be looking at my temp display for my heated air from the exchanger but now my temp display is reading 8888. Gotta look into that tomorrow. I suspect the thermocouple has a bad connection somewhere. (sigh) Anyways, the house went from 63 to 70 in no time.
    CleanFire, jtakeman and imacman like this.
  14. don2222
    don2222
    Salem NH
    Hello
    It is 6:15 AM and 35 Deg Out!
    64 Deg in the living room!
    Last night I closed the gable vents in the attic. I made insulated trap doors with a latch so I could seal them up tight. That always makes a huge difference by not letting the cold air come in and suck the heat out like a vacuum cleaner!!
    I will think about turning on any heat at all when we wake up. :)
    Workshop is 63 Degs F
    Shed is 51 Degs F
    Basement is 65 Deg F
    CleanFire, ChandlerR and IHATEPROPANE like this.
  15. Rich250
    Rich250
    Berks County PA.
    turned on the baseboard heat in the living room and bedroom and woke up to 70 deg. It only got down to 40 deg. so no stove yet
  16. imacman
    imacman
    Denver, NC
    Doubtful.. Jay is in for a long winter of :heidi:
    CleanFire, jtakeman and IHATEPROPANE like this.
  17. imacman
    imacman
    Denver, NC
    Was 32* at 6am......heating system was ON. :shiver:
  18. jtakeman
    We had frost this AM, House held the heat pretty good as it was still 69ºF this morning. Buggy had a frost on it too. Used the baseboard heat in the bath for the AM shower, And heat in the buggy for the ride in. :shiver:
    Suns shinning so I bet we get some solar that warms the shack and no heat again tonight. :dennis:
  19. don2222
    don2222
    Salem NH
    Well, I just opened up the valve for a few drops of Liquid Propane, 30k BTUs to take the chill out. No Big Blue 109K BTU Budarus Boiler or big Satin Black 61K BTU Harmy yet!
  20. ttdberg
    ttdberg Pellet Pig
    CT
    Let the P68 run last night, and glad we did - it was 33 outside this morning.
    CleanFire, imacman, don2222 and 2 others like this.
