Oh now I'm happy.... this is happening.
Discussion in 'Modern EPA Stoves and Fireplaces' started by FatBoy85, Oct 16, 2017.
  1. Warner
  2. Warner
    Yay! I finally figured out how to post pics!
    Horkn, Thor, brenndatomu and 5 others like this.
  3. wildwest
    :dancer:
    Horkn, CoreyB, HDRock and 1 other person like this.
  4. FatBoy85
    FatBoy85
    Washington State
    IMG_3996.JPG IMG_3997.JPG Alright it got too anticipated, fire in the hole!!!!
    milleo, papadave, mike bayerl and 7 others like this.
  5. Warner
    And so it begins....
  6. HDRock
    Put some more wood in there and open the windows:D:dex:
    Shoot I remember first fire in my EPA stove it was 62 out
  7. FatBoy85
    FatBoy85
    Washington State
    Sure will! Hahaha man this thing is drafting well!! And its not even wide open. Half
    papadave, leoht, Horkn and 3 others like this.
  8. FatBoy85
    FatBoy85
    Washington State
    Wow that's just beyond pretty...
    milleo, TBONE, savemoney and 12 others like this.
  9. HDRock
    Looks like chimney is real close to the peak, should draft good
    savemoney, leoht, Horkn and 5 others like this.
  10. FatBoy85
    FatBoy85
    Washington State
    Its right there. The roof collar flange had to be bent over the peak. I will take pics when I can get up there again.
    savemoney, Horkn, Thor and 2 others like this.
  11. HDRock
  12. FatBoy85
    FatBoy85
    Washington State
    I just reloaded it. 62° mostly sunny and windy out. Looks like this might last until the sun goes down. Chunky monkeys
  13. FatBoy85
    FatBoy85
    Washington State
    Wow, Ive got it shut down completely on the doohickey, we're at 450 and golden. Every room has a window open at least. IMG_4006.JPG IMG_4007.JPG
  14. HDRock
    Well you got fire now all you need is:cheers::pete:
  15. HDRock
    Do you have an IR thermometer?
    Every one of those Rutland thermometers I've had are about a hundred degrees off
  16. FatBoy85
    FatBoy85
    Washington State
    Thanks for reminding me I bought one like 3-4 months ago at HF. Gonna use this now, thanks for letting me know.
    Horkn, Thor, CoreyB and 1 other person like this.
  17. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I imagine your house must smell as good as mine does right now! I'm sitting.out on my porch with the windows and doors open. It's kinda like after eating bad Mexican. 20171016_182953.jpg
  18. HDRock
    It's not a problem monitoring your stove as long as you know how far off it is.
    My digital thermometer is about 60 degrees off
    papadave, Horkn and FatBoy85 like this.
  19. FatBoy85
    FatBoy85
    Washington State
    Lol! Its actually smelling like clothes that aren't smelling good from the dryer. Like they haven't been soaped. The paint isn't thick at all. Just a simple powdercoat.
    HDRock I took the IR around the glass, stove top and then the pipe. So since it wasn't consistent I'll mention that on the door it was around 630F, maybe 550F in spots where no fire was around. Stove top was registering close to 500F in the middle by the Rutland just as you said its registering at 400F. 95-100 degrees off depending on a 5 inch square. Back of the stove area was just shy of 400. Pipe registered about 177F in the middle.
    savemoney, papadave, Horkn and 2 others like this.
  20. CoreyB
    CoreyB
    South east iowa
    Did I miss what stove this is. It looks pretty good!
    savemoney, Horkn, Thor and 1 other person like this.
