  1. bogieb
    Yeah, most people oil around here. Just within the last couple of years have I seen the other stuff. Either way, I could have it done locally (amazingly enough!)
  2. CleanFire
    CleanFire
    There's no real hard rule on when to undercoat - prior surface prep is best though, which means physical inspection of the frame underneath, removal of any scale rust, and prep for any internal frame rail application needed .. it's worth the extra bucks, to get a good inspection & surface prep.. Which is usually $100-250, depending on # hours of lift time needed.
    For a multi-year application that will last, an epoxy-based product like POR-15 is best.
    ( If you do oil-undercoat, find a dirt road at the end of town on a dry day, and get some off-road time in to lock the oil undercoat to the frame.. )
  3. bogieb
    That's not a problem, I run a dirt road every night headed to my evening job (only run it when dry - wet it is a rutted mess as it is a fairly popular shortcut).
  4. CleanFire
    CleanFire
    That'll do it. :thumbs: When everything oiled looks covered in a even layer of road dirt, you're good to go !
  5. IHATEPROPANE
    IHATEPROPANE
    Pellet stove passed inspection. There was even a tape measure involved in the process. Will be firing it up soon enough.
    bogieb, imacman, schoondog and 8 others like this.
  6. CleanFire
    CleanFire
    :thumbs:
    imacman, slvrblkk, jtakeman and 2 others like this.
  7. jtakeman
    Time to celebrate!! :cheers:
    :drunk:
    I took tomorrow off, With this awesome weather, We just have ta hit the water!! :D
    :seasoned:
    PelletHound, bogieb, imacman and 4 others like this.
  8. IHATEPROPANE
    IHATEPROPANE
    Fired her up as soon as I got home from work. Perfect pellet stove weather.
    Really nice lively flame. A little louder than the EP, but not bad. Much more quiet than the West Point. Hey Skeet, lets bring on the cold!!
    PelletHound, bogieb, imacman and 5 others like this.
  9. slvrblkk
    slvrblkk
    Northampton, PA
    I can't wait for your "review" of the stove! Congrats again!
  10. jtakeman
    I liked everything but that part! :p
    :picard:
  11. CleanFire
    CleanFire
    :picard: Welcome to the dark side.. :D
    Nice looking stove IHP ! What kind is it, please? Looks like it holds lots of pellets. :yes:
    will711, PelletHound, bogieb and 4 others like this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Looks like a 3 bagger.
  13. wildwest
    Manual lighting trick? He's been using super cedar but I just froze myself looking for them in the garage, and no hand sanitizer here. Did I see cotton balls in alcohol could be used (not sure how hot that gets)? Newspaper and and cardboard? Dry dead weeds from outside?
  14. IHATEPROPANE
    IHATEPROPANE
    Its the new Englander smart stove. Like STB said, three bag hopper. It actually holds three....barely.
    bogieb, imacman, eatonpcat and 4 others like this.
  15. IHATEPROPANE
    IHATEPROPANE
    No newspaper or cardboard or cotton balls or weeds
    bogieb, imacman, slvrblkk and 2 others like this.
  16. CleanFire
    CleanFire
    Propane torch handy? A few inches of pellets in the burn pot, and less < than a minute of flame should get them going quick.
    bogieb, imacman, schoondog and 2 others like this.
  17. CleanFire
    CleanFire
    I like smart ! :cheers:
  18. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You can soak pellets in rubbing alcohol. That is what I use in my burn pot when my igniter isn't working.
    bogieb, imacman, slvrblkk and 3 others like this.
  19. wildwest
    :binoculars:
    Thank you pellets sloshed in nail polish remover looks promising!
    Yes, there is one out there.... somewhere......:binoculars:
    ETA, up and running, THANKS!!
  20. IHATEPROPANE
    IHATEPROPANE
    I would stick to the alcohol. The acetone i believe will burn off and dissipate much faster.....the pellets may not stay lit.
    bogieb, imacman, savemoney and 3 others like this.
