Splitter mod finally
Discussion in 'Chainsaws and Power Equipment' started by DonE, Sep 29, 2017.
  1. DonE
    DonE
    NE GA
    Been kicking around the idea of putting tables on my splitter for a while now. I finished them up today. I did smaller tables than many because I still use the vert/horoz. feature quite a bit and the larger tables would have taken that option away. I sure was tired of bigger rounds falling off on my legs/feet or the engine. I'm not the best fabricator or welder, but I feel like they will hold and can't wait to try them out. split1.jpg split2.jpg split3.jpg split4.jpg split5.jpg
  2. Well Seasoned
    Awesome job! That'll make life way easier!
    papadave, Thor, Eric VW and 3 others like this.
  3. Canadian border VT
    DonE I think it looks great!
    papadave, savemoney, Eric VW and 3 others like this.
  4. Mag Craft
    That should help from picking up a lot of fallen pieces while splitting. Looks great.
    papadave, savemoney, Eric VW and 2 others like this.
  5. HDRock
    Nice job :thumbs: that's going to be nice , I know you will love it
  6. Horkn
    Great job! That craftsman is the same as the MTD we have up north. I can tell you that those tables are much better built than the stock "wings"that are on there. Those things bend if you look at them funny.
    papadave, HDRock, Mag Craft and 4 others like this.
  7. Eric VW
    papadave, HDRock, Thor and 2 others like this.
  8. savemoney
    sweet, should serve you well. safer too!
    papadave, HDRock, Horkn and 2 others like this.
  9. MikeyB
    MikeyB
    Long Island NY
    Don E, that looks freaking awesome. Log tables make life easier that's for sure. How did you fasten your sheet stock to the tubes?
  10. Armbru84
    Armbru84
    Sparta, Michigan
    That looks really good and it will make splitting a lot easier!!
    HDRock, papadave and p61 western like this.
  11. TurboDiesel
    Looking good, Don!
    You'll probably want to add a stop on each end of the tables to keep the splits from vibrating off the ends. I used small pieces of angle to keep pieces from falling on the filter/return hose.
    (And a cover over the filter )
    metalcuttr, Dancan, HDRock and 4 others like this.
  12. DonE
    DonE
    NE GA
    I used pop rivets to anchor the sheet metal down. I was going to weld it on and then thought I might want to change the sheet out some day in the future and its a lot easier to drill the pop rivets than to grind the welds off.
    I like the cover over the filter.... that will be added to mine soon.
  13. TurboDiesel
    :yes:
    metalcuttr likes this.
  14. TurboDiesel
  15. Pa. Ben
    Pa. Ben
    Ligonier Pa.
    Nice job I was thinking about doing the same exact thing to my splitter.:thumbs:
    HDRock and TurboDiesel like this.
