Check out this chimney.....
Discussion in 'Modern EPA Stoves and Fireplaces' started by mjstef, Sep 25, 2017.
  1. mjstef
    mjstef
    Northwoods Wisconsin
    Was getting ready to drop in a liner to install a Lopi Answer insert when i found this. It is the joint between the 1st and 2nd sections of flue from the ZC fireplace......
  2. papadave
    Whoa, dat ain't right.
    And, welcome aboard.
  3. chris
    another quality install ( ya right) from the looks of the flue must have been a gas unit?
    VOLKEVIN and Eric VW like this.
  4. Eric VW
    Welcome to FHC mjstef :handshake:
    Looks like you've got some chipping to do?
    What's the diameter?
  5. mjstef
    mjstef
    A Marco wood fireplace installed in the house when it was built in 05...
  6. chris
  7. FatBoy85
    FatBoy85
    Washington State
    Uh oh. I'm in no means even a beginner with chimney work. Does this mean you have to give the owner bad news?
