Dolmar 6400/7900 crank spun
Discussion in 'Chainsaws and Power Equipment' started by BuckthornBonnie, Sep 24, 2017.
  1. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Flywheel side--- slip fit into bearing.
    Anyone else experience this before on this model? Usually I find spun bearings/crank on the pto side.
    HDRock likes this.
  2. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
  3. HDRock
    Where is all the saw boys :) :sleeping:
    p61 western and BuckthornBonnie like this.
  4. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Haha. Busy... or on OPE.
    Here's my thoughts-- this saw had a history of a scuffed piston. My buddy bought it and I gave him a big bore kit to try. He built it up but never told me that he noticed a crank wiggle... He got bad advice from a local mechanic who told him it was fine. I didn't find out about the wiggle til this spring when he brought it to me w idle / flooding issues. I rebuilt the carb, worked ok but wasn't right. I finally tore it down and found it.
    Just goes to show: NEVER build up a saw without thoroughly checking the bottom end and replacing items if needed.
    Horkn and p61 western like this.
  5. HDRock
    Sounds like a plan :)
  6. p61 western
    p61 western
    Northern California
    I have never come across this problem before. I have come across case halves to loose for the bearing though.
    BuckthornBonnie and HDRock like this.
  7. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I've seen it on an ms460... pto side. Got a crank from a junker case and rebuilt it with new bearings.
    This saw needs a new crank, bearings, seals, gaskets, cylinder, piston, coil clips, etc. etc.
    p61 western likes this.
  8. p61 western
    p61 western
    Northern California
    Is it maybe by chance the bearing itself? Do you have a new bearing on hand to try on the crank?
    cus_deluxe likes this.
  9. p61 western
    p61 western
    Northern California
    Well dang sounds like a full rebuild then. At least you will know it will be in good shape afterwards.
    BuckthornBonnie likes this.
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    We may part it out... already put too much into it. Plus I don't fully trust the case screw holes. Ill need to take a closer look this weekend.
  11. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Tried it on a new bearing, yep. It's shot.
    cus_deluxe and p61 western like this.
  12. p61 western
    p61 western
    Northern California
    Well that sucks. Are you going to build it or part it out?
  13. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Part it out... if it were a Stihl? Probably build it. Hate to say it, but I have access to Stihl parts and enjoy the process.
    Dolmars/Makitas are fine, just not into 'em.
    Now I'm looking for an 046-660 project saw.
    HDRock and p61 western like this.
  14. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Hmmm...AM big bore, not much cleanup done to ports, 3 yr life but built on questionable case:
