Need help to stay warm
Discussion in 'Everything Else (off topic)' started by Backwoods Savage, Sep 3, 2017.
  1. Backwoods Savage
    Outside, that is, especially when sitting still, like when hunting from a tree stand. But also have big problems with feet and legs staying warm, even today so you can imagine what winter is like.
    Yes, I know the tricks about layering and wearing wool and wearing felt packs etc but figure there has to be more out there.
    So far I have found a little information about some types of clothing. Eric VW did point me toward alpaca and it is good except I'm not particular about how they are made. I have also found out that bison is supposed to be great and so is yak but musk ox is supposed to be the very best of the best. The trouble is, it is also the most expensive and expensive perhaps should be in capital letters! Super high. I also think all the musk ox stuff is knitted which I am not a fan of.
    One more thing is that whatever I wear I like it to be super soft as I have rather sensitive skin. But things like smart wool is okay.
    Sadly one can't seem to find felt packs any longer. They have something they say is better but I've not found this to be the case.
    For boots, I've tried many. Thinsulate is supposed to be the greatest but I find it very lacking. Yes, it is nice that it is not so bulky but even with 1600 grams, my feet get really cold fast. Even when working in winter.
    I have found that wearing levi's that are fleece lined (better than flannel) is super great but sometimes one has to wear long johns under them. What kind?
    Gloves. I find most to be lacking greatly. For work in winter so far I've found nothing better than a pile lined glove. I've not found any insulated glove that works well.
    Heat packs. Sometimes they can work fairly well except those you put inside of boots. They need air and once inside the boot, they don't put out heat very long. They work good in gloves while hunting but not when working.
    One thing that is not meant for a heat pack are Thermacare wraps (the off brand are mostly junk). I really like the back wraps and they will keep you warm for 12 hours or longer. I've had them last 15 hours. This winter I plan to try the small wraps on my toes to see if that will work.
    Parkas are much, much better than jackets.
    Someone pointed out to me that a ThermaCell without the pad and put inside a coat would work out nicely so I may try that but worry a bit because that is burning butane. What about the exhaust?
    For material, I really do like fleece but many seem to be going away from it and I know not why. I did find some super shirts from Legendary Whitetails last winter and I see they have them back this winter. I bought extra last year thinking they probably would not have them back. I usually do this when we find something good because they seem to think thing will sell for only one or two years so we stock up. I'm still wearing some shirts we bought around the year 2000. Not a problem here.
    Anyway, I'm all for ideas.
  2. Grizzly Adam
    Grizzly Adam Guest
    I removed snow for 12 hours in -40 weather at work last year. I wore a fhc hoodie under my oversize wool over coat. I had my ushanka on, rubber dipped thinsulate gloves, and some thick super insultated socks the old lady got me for xmas. They have a furnlike lining in them. Just had my regular work boots on over top. No part of me other than my nose and brow felt the cold.
    I also broke out a cowl whenever the weather was warmer and the ushanka was too warm.
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
  4. Eric VW
    Have you tried some silk LJ's or socks Backwoods Savage? As part of the layer technique that you're well aware of....
    IIRC, you bought the the regular length alpaca socks, yes? Mine almost go to the knee, and they don't slide down toward my shin...
    :thumbs:
    KsKent, Backwoods Savage and wildwest like this.
  5. Jack Straw
    Jack Straw
    I've always had the problem of my feet sweating and then getting cold. :doh:
  6. wildwest
    x2
    I bought some faux sheepskin insoles to try this winter, and still have not tried the foil heat reflecting liner.
    Also, I heard some sewing/fabric stores carry the felt liner in bulk.
  7. Eric VW
    Dennis, we need to create a radiant floor mat for you if you're in one of the wood stack blinds. That would keep your feet warm for sure!
  8. Jack Straw
    Jack Straw
    Heated milk crate!
  9. Gasifier
    When working outside, take some time and set up/build our best friend, that is called a fire! Take breaks near the fire including having a chair near it. :fire:Remove gloves and get warm!
  10. brenndatomu
    [​IMG] Might work slightly differently with the plastic ones...:whistle:
  11. Paul bunion
    Paul bunion
    I like a jacket/shell with pit zippers that allow you to vent when you are active and then zipping back up when still. With them open there is much tendency to overheat and start sweating. What sweating you do has an easy way to get out. They really help keep that wet chill off your body and keep you more comfortable overall.
    A pair of gaiters on the legs can help also. They keep your boots drier. And keep out the snow.
    Eric VW and Backwoods Savage like this.
  12. brenndatomu
    I have never been able to keep my hands and feet warm...tried just about everything...I now have a pair of battery powered heated socks that I want to try out next.
    I have learned to bring 3 pairs of gloves when I go out on repair calls at work in the wintertime...wear one and have the other two warming in the truck to swap out as needed...the third pair is incase one of the three gets soaked.
  13. Backwoods Savage
    Yes, I do have both underwear and socks in silk.
    Eric VW likes this.
  14. XXL
    XXL
    Ontario, Canada
  15. Flatlander Pete
    Flatlander Pete
    Go Dawgs!
    I was given one of these as a Christmas gift last year. It works very well! I wouldn't have purchased one and now I look into other manufacturers'. Technology has made this type of clothing much more efficient than years ago. I'd suggest a look Dennis!
    I have also been known to wash my duck hunting chest waders and wear them in the deer blind! I don't like to be cold!!
  16. JustWood
    JustWood Guest
    Under Armour is awesome.
    I wear heavy sweatpants and an underarmour hoodie under light non insulated bib overalls .
    Works well.
    Backwoods Savage and Eric VW like this.
  17. TurboDiesel
    :eek:
  18. Eric VW
    Honestly, I'd like to know how the Ornery One handles the cold? If she does well with it, you could just sit by the Fireview and let her shoot supper:rootintootin:
    Cold weather problem solved!
    :thumbs:
    :yes:
    :handshake:
  19. TurboDiesel
    Hunt from the sliding glass door...:handshake:
    Yes...the one next to the Fireview...:dex:
  20. Eric VW
    Even bettah!
