Splitter wont start
Discussion in 'The DIY Room' started by Mr A, Sep 2, 2017.
  1. Mr A
    Mr A
    hello. Long time no see. I have neglected my log splitter.Left it ot in the rain un covered, and now it wont start. I'm thinking I need to drain the old fuel, change the spark plugs, and air filter. Change the hydraulic fluid. Clean the carb. am I on the right track? any suggestions? Thanks in advance. It's a 5hp honda engine
  2. Grizzly Adam
    Grizzly Adam Guest
    We had a cracked primer bulb last year from storing it outside. Maybe check that too.
    bobdog2o02 likes this.
  3. TurboDiesel
    Drain the fuel and refill .
    Try the carb cleaning next if it still doesn't run.
  4. Canadian border VT
    ^^^ I would wait on changing hydraulic oil.. should have no effect on starting.. pull plug after couple cranks if wet not a gas problem (after you change gas put fresh gas in it, if dry not getting gas.. check fuel lines and carb.. then check air filter and spark...
    engines only need 3 things to run... fuel air and spark they should start.. did not say run well but start
    J. Dirt, papadave and fox9988 like this.
  5. gmule
    gmule
    Conifer Colorado
    drain the tank and carb and refill with fresh fuel.
    give it a spray of starting fluid to help it fire off easier
  6. TurboDiesel
    Check for spark
  7. Mr A
    Mr A
    Yep. start simple and work down the list of potential problems. I'll start with fresh fuel.
  8. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    This
    TurboDiesel likes this.
  9. JCMC
    JCMC
    Just outside of Shushan, NY
    yep check for spark!
  10. bushpilot
    bushpilot
    Eastern Washington
    Give it a shot of starting fluid. If it pops, you have spark. Then you will know whether to pursue spark or fuel.
  11. Kimberly
    Kimberly
    The Kangaroo State
    The first thing I always check for is sparkies; and I like to pull the plug and check it at the gap; no sparkies there, then check it at the wire. no sparkies there, then you move along to the coil, electronic module if it has one, etc. If good sparkies, then it must be fuel related. Sitting out in the rain probably means the stuff that makes the sparkies is all wet and not working.
  12. Kimberly
    Kimberly
    The Kangaroo State
    Yes, UV rays are bad on plastics. However, so it the alcohol in the corn gas scam we are forced to endure. I wonder if a petition would work...
    BigPapi likes this.
