Cut about 1,200 pounds of oak tonight
Discussion in 'The Wood Pile' started by firecracker_77, Mar 1, 2014.
  1. firecracker_77
    firecracker_77
    IL
    Got off work at about midnight and went about cutting a bunch of oak logs and larger branches. Was a 192 / 441 date night. My wood is in a commercial area so I can run my saws at odd hours of the night if I want.
    Hand filed the 441 chain, but it was not very sharp. Got a grinding disc on the way for the PalletPete chain sharpener, so that will be better. Saw has enough muscle to power through, but there is no substitute for a sharp chain. Anyway, the process was as follows: sledge the logs to break them free of the frozen ground, roll them up onto a big flat round, cut them against the grain, stand 'em on end, and noodle the rest of the way or cut them traditionally into smaller pieces. I have plenty of wood to get through and this wood should be ready by next year. It was in log form for about 9 months. Now, it's split.
    Was a blast except for when I flooded the 441 and couldn't get it started initially. Pulled a million times, then I yanked the plug, pulled a couple times, re-tightened the plug, and it went right away.
    Any tips on how not to flood this saw? I'm not good with it yet. The 192 and 290 are a breeze to start. I struggle with the 441 until it's warm and then it starts on one pull.
    Was baby sitting my daughter at the office tonight and listening to some hair metal before I went out to cut the wood. Here's a clip of her enjoying dad's music. :thumbs:
    Snigg, brokenwing, Chvymn99 and 2 others like this.
  2. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    I did the tube amp! And the music choice. If you hold the saw wide open throttle no choke, sometimes you can clear a flooded condition. Theory being, low vacuum at WOT, minimum fuel being pumped in. Keep it WOT if it hits, and it will take about 5-10 seconds to clear out.
  3. swags
    swags Moderator
    What do you use for lights to cut at night?
  4. Firewood Bandit
    Firewood Bandit
    On most saws, as soon as the saw "pops" however slight, take the choke off and leave on high idle then pull.
  5. firecracker_77
    firecracker_77
    IL
    There are parking lot lights nearby that illuminate enough to see.
