Chimney and Stove selection, Englander Madison?
Discussion in 'Modern EPA Stoves and Fireplaces' started by CoreyB, Aug 25, 2017.
  1. papadave
    I don't think the baffle is ceramic, but it does break easily. I clean top down and the baffle needs to come out before hand or it's VERY possible to put the brush right through it.
    The Madison is not the same as the 30. I think there are two sizes of the Madison too.
    Eric VW, HDRock, CoreyB and 3 others like this.
  2. brenndatomu
    Well, technically they do call many of the baffles "ceramic". But it is a ceramic fiber board...think fiberglass (but with ceramic fibers) compressed into a rigid (but kinda fragile) "board"...
    Never heard of ceramic tubes...not sayin they aren't out there, just not common at all.
    No, the Madison is not the same as the NC30, and yes there are two sizes of the Madison.
    papadave, Eric VW, Ronaldo and 4 others like this.
  3. papadave
    Tubes in the 13 and 30 are stainless steel.
    Cool....good info.
    Eric VW, wildwest, Ronaldo and 3 others like this.
  4. CoreyB
    CoreyB
    South east iowa
    This thread is garnering a lot of great info. I greatly appreciate that. I really do need details to be comfortable in a decision.
    How hard is it to remove the baffles on the Englander stoves? Is it just twist and lift? Or did I read that wtong?
  5. papadave
    The 13 baffle is a tight squeeze.
    On the 30, it's one screw to pull the front tube, tilt out the baffles, and you're done. Very quick. Takes longer to find the screwdriver than it does to remove those.:picard:
    No idea on the Madison stoves.
  6. HDRock
    Picture of the Madison, front tube not visible
  7. Canadian border VT
    are the NC 30 no longer available? would be my goto on budget CoreyB if you are on tight budget that's the stove .. papadave and many other have them can be found under 700
    Horkn, Eric VW, wildwest and 3 others like this.
  8. HDRock
    You said something about where the old stove use to be , is there a hearth already in the house or what ?
  9. papadave
    Nice pic HD.......where'd ya find that?
    Horkn, Eric VW, wildwest and 2 others like this.
  10. brenndatomu
    The NC30 is still available...haven't seen any great sales on it since last spring ('16) when HD Durango had 'em for $500 basically.
    Hey CoreyB , I see a Drolet Myriad on Ebay in Wheatland Iowa, is that close to you? That is a highly respected model of stove too...basically Drolet's version of the NC30...this one is listed as "buy it now" for $350...or "make an offer" I love those...I've gotten some great deals that way! :yes:
    wood burning stove used
    EDIT: Looks like it may come with chimney too? Stove pipe at least (and double wall I think)...wording is a little vague on that. That wood be a "smoking" deal :whistle: if it does come with the chimney pipe! :)
    Seller is rated 100% too...that's always good to see.
    Horkn, Eric VW, CoreyB and 6 others like this.
  11. HDRock
    It was in my files with the rest of Madison stuff.
    I was trying to remember exactly where I got that [​IMG]
    Maybe it was some other web site , maybe a pic Kimberly took [​IMG] but I know it is the Madison :yes:
  12. HDRock
    Found this in files, good read
  13. papadave
    Those are nice stoves. A place near us sells them....I like the door latch on the Drolets I've seen.
    Even w/o the pipe, that's a great price if it's in good shape. Really though, other than popped welds, what could be wrong with it?
  14. brenndatomu
  15. brenndatomu
    I just remembered something on buying Englander stoves...there is a company that sells on Ebay that has factory seconds for a nice savings, AMFM Stoves...usually a little bit of nothing wrong with them. People have spoke highly of them. They have a Large Madison (labeled Timberidge for Lowes IIRC) right now. Free shipping to a local LTL terminal too.
    TIMBER RIDGE 50-TRSSW02 Large Wood Stove, heats 2400 sq ft,- New in box
    Horkn, Eric VW, papadave and 5 others like this.
  16. HDRock
    Yep, TIMBER RIDGE - Brand New Factory Seconds or Manufacturer Refurbished S
  17. CoreyB
    CoreyB
    South east iowa
    It would be a six hr round trip and I would have to see if I could borrow a truck. I doubt I could load it in the mini van without tearing something up. Hmm. I will call tomorrow anyways.
    Horkn, Eric VW and wildwest like this.
  18. CoreyB
    CoreyB
    South east iowa
  19. savemoney
    What ever option you go with, you must be able to keep the house warm in the event you are away, or sick or have something that limits wood heating. 6 ladies in the house, can they fetch the wood and keep things going without you. If no, you need a back up plan even if it is electric space heaters.
    Horkn, Eric VW, wildwest and 5 others like this.
  20. CoreyB
    CoreyB
    South east iowa
    I do already have 2+ years supply within 50 yards of the house. And another 2 cord in the timber stacked ready to be hauled up. The wife can handle keeping it up and the girls are pretty good at fetching it. But back-up is the plan and when I save up enough money I will put a new l.p. furnace in unless I can find a better alternative heat source. I am also adding a green house / 3 season structure to try and capture as much of the southern sun during winter . But that is more then likely next year or so.
    Horkn, HDRock, Eric VW and 3 others like this.
