What's my problem?
Discussion in 'Chainsaws and Power Equipment' started by Well Seasoned, Aug 12, 2017.
  1. Scotty Overkill
    Sounds like the pawls aren't extending out. Take the recoil off and have a good look-see....
    If that don't work, you could always resort to this method:
    It don't work either, but sure makes ya feel better!!!
  2. Well Seasoned
  3. Eric VW
  4. SCOTTY1848
    SCOTTY1848 Banned
    Up State NY
    That or your infrared thermometer should tell you what the problem is I read it on the internets so its gots to be true!!
  5. hotshot
    hotshot
    USA
    Your balls are rusty, gunked & crusty! :rofl: :lol:
    Do a Youtube search for "how to fix a starter clutch on a briggs and stratton engine", and the rope starter itself is probably fine.
  6. OldJack
    OldJack
    Saskatchewan, Canada
    True. First, take off the flywheel cover. There should be a 4 cornered crankshaft extension with a small hole in the end. This is the starter. Oil generously and flip the mower over on it's side (carb up). Try spinning it with your fingers. If there's no grip on the crankshaft your balls are stuck. Rotate the starter SLOOOOWLY so the oil can get all the way around. Light hammer taps may loosen the balls up. Ladies go easy. If that doesn't work take off the screen and gently tap on the lugs that the screen screws go into and turn off the starter. It turns off counterclockwise when you're facing the flywheel side of the engine. Replace the starter if oil and a big hammer doesn't loosen it up.
    clemsonfor, blacksmith, Hammy and 5 others like this.
  7. HDRock
  8. Well Seasoned
    Prefect, thanks!
    clemsonfor, blacksmith, Hammy and 4 others like this.
  9. Well Seasoned
    Yup, it was my balls! All cleaned & oiled up now, thanks!
  10. HDRock
    Yippee , now ya get to mow da grass :D [​IMG]
  11. Well Seasoned
    I did this morning. Hit the field, 30" of thick chit taken down in moments.
    hotshot, clemsonfor, papadave and 7 others like this.
  12. Eric VW
    Amazing what greazed up bawlz have done for ya.....:whistle:
  13. Horkn
    I've got a similar gunked up balls issue.
    On my motorcycle's clutch release actuator.
    A good scrubbing will degunkify the whole deal. I just have to get all 11, yes 11 little balls in their places, at the same time.
    Eric VW , do you want a picture? Lol
    clemsonfor, HDRock, papadave and 5 others like this.
  14. Eric VW
    No need to photographically document your tiny bawlz....even if you have 11 of them.:yes:
  15. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I think I heard the mower scream twice! Call the police!!!
    Hammy, clemsonfor, Horkn and 7 others like this.
  16. stihl sawing
    stihl sawing
    Arkansas
    Had to clean those many times to get it working, actually you don't want any oil in there. fine dust will get in there and gunk it up again. I always left em dry.
    Hammy, clemsonfor, Eric VW and 5 others like this.
  17. Scotty Overkill
    Well, take better care of yer balls, try cleaning then once in a while, for Petes sake!!
    :rofl: :lol::rofl: :lol::rofl: :lol::emb:
  18. papadave
    That was mower abuse........I'd hate to be one of her kids. :hair:
    She obviously has anger management issues.
    Hammy, clemsonfor, Eric VW and 4 others like this.
  19. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Ya, I think that her thoughts just might be energetic in their own way.... :whistle: I think most of us here if we tossed something would stop realizing that if we break something else that we would have to fix that too OR we would do a better job of completely destroying. :dex:
    Hammy, clemsonfor, Eric VW and 3 others like this.
  20. yooperdave
    Just found this thread. It's amazing that it has stayed on track....reasonably!
