Farmertec 272xp P&C, or What's Wrong with this Picture?
Discussion in 'Chainsaws and Power Equipment' started by MrWhoopee, Aug 8, 2017.
  1. MrWhoopee
    MrWhoopee
    Shingletown, CA
    I've been trying to get the piston into the cylinder on the 272xp upgrade of my Husqvarna 61. No matter what I tried, I just couldn't get it in. I tried a homemade compressor, I bought a Stens ring compressor set. Nothing worked.
    Last night, about 3:30 am, as I lay there wishing I could sleep, something occurred to me. This morning, I took the ring off the piston and put it in the cylinder.
    The red arrow points to the "gap". It measures .006 in.!
    blacksmith, Woodsnwoods and Warped5 like this.
  2. MrWhoopee
    MrWhoopee
    Shingletown, CA
    I sparked a little off each end, now it goes together with no problem! I went ahead and ordered a Caber ring anyway. When I tried to set the cylinder, I noticed the surface wasn't flat. The gasket was still there, so I removed it. The surface still wasn't flat, there was a SECOND gasket under the first! The idiot who replaced the piston hadn't removed the original gasket. :doh: Let's see, who WAS that idiot?:whistle:
    Tightened down the cylinder, measured .018 squish. Should I leave it? If so, anybody used Permatex #2 as a sealant?
    blacksmith, cnice_37 and dougand3 like this.
  3. dougand3
    dougand3
    North Alabama
    I've had to file off rings before and learned what you just learned. Check in jug first. I use Prematex Motoseal if base gasket delete. .018 is pretty good, tho.
    SCOTTY1848, blacksmith and Moparmyway like this.
  4. 94BULLITT
    94BULLITT
    Frederick County, VA
    .006'' is probably in the ball park for that saw.
  5. MrWhoopee
    MrWhoopee
    Shingletown, CA
    The pin is .060
  6. Oldman47
    Oldman47
    Illinois
    The pin had better not be affecting the ring gap in the cylinder. The rings are shaped to fit around the pin, not run into it.
  7. brenndatomu
    Yes, and yes. Should be fine...and 0.006" is fine too...whatever was causing the piston to not go in, that wasn't it.
    Mag Craft and hdtoolmkr765 like this.
  8. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Funny, as soon as I widened the gap it went in with no problem. To be clear, the pin is 10x wider than the gap was.
  9. brenndatomu
    Yup, and the ring is made to wrap right around the pin. It has no bearing on the ring end gap at all...at least it shouldn't. If you had to open the gap up to .060" (+) to get it in, then your piston/ring(s) are not a matching set...in other words, one of them is wrong.
    Either that or the ring was on top of the pin...but if you struggled with it that much, I doubt that would be the case each and every time you attempted to install. At least you didn't force it...I've seen stuff brought in for low/no compression that were "just rebuilt" turns out the rings were either upside down, or just sitting on top of the locating pin...even seen pistons installed backwards. :picard:
    A wide end gap will contribute to blowby. Hopefully the Caber ring will work for you right outta the box.
    hdtoolmkr765 and 94BULLITT like this.
  10. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    All the above are true, .006 is where I'd want the gap on that saw. Like stated above you've got some other issue going on. If you look at the pin in the ring groove, it is typically not dead center in the width of the groove. The rings are typically not flat on the ends either, so the gap between the bottom of the pin and the ring groove is where the long ends of the ring goes. I'm wondering if you possibly were trying to put it together with the ring upside down.
    brenndatomu likes this.
  11. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    I see that brenndatomu and I were typing at the same time...
  12. Mag Craft
    Next time you measure the piston end gap push it in with the piston just above the exhaust port. Then measure it there.
    The .006" sounds ok to me too. The .018" of squish will work but is starting to get a little tight. The bigger the piston the more expansion so on saws with a little more CC's I try to give them around .020" squish or more. Just my 2 cents.
  13. MrWhoopee
    MrWhoopee
    Shingletown, CA
    Yes, the pin is offset towards the top of the groove, but the ends of the ring were flat so they were binding on the pin, preventing the ring from compressing adequately. It will all be resolved when the Caber ring arrives.
  14. brenndatomu
    Ahh, yes so either the wrong ring or it was made improperly. The Chinese parts don't have the best reputation for consistency...you get one of something and it is fine, then the next one is made wrong (or at least poorly)
    There is a rule of thumb on ring gap...I don't remember exactly, but its something like 0.002-0.003" per inch of bore diameter.
    That may vary some by size and type of engine too...IDK...it'll get ya in the ballpark though
    hdtoolmkr765 likes this.
  15. cus_deluxe
    cus_deluxe
    Northern Michigan
    If it was me i would open up that gap a touch, ive always heard .004-005 per inch of bore for general 2-stroke applications. A little more for "modded" engines. being a 52 mm bore that would be a bare minimum of .008.
    94BULLITT likes this.
  16. 94BULLITT
    94BULLITT
    Wiseco says you generally need .004-.005'' per inch of bore on a 2 cycle.
    brenndatomu and cus_deluxe like this.
  17. cus_deluxe
    cus_deluxe
    Northern Michigan
    Well there ya go.
  18. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
  19. cus_deluxe
    cus_deluxe
    Northern Michigan
    Yes?
  20. Scotty Overkill
    Was it posed yet as to whether or not the ring was installed upside down when attempting to put it together? The rings have a taper on either side of the gap, the pin is offset in the groove to accept that taper......
