Bridges in the woods
Discussion in 'The Wood Pile' started by Erik B, Aug 2, 2017.
  1. Erik B
    Erik B
    Western Wisconsin
    I finally got the trail in my woods cleared enough to drive on it. I still have 2 trees that are bridges right now. One is an oak and the other a poplar. At least they are off the ground for now. Before I start with these two, I have other trees that came down blocking the woods road. DSC02703.JPG DSC02705.JPG DSC02707.JPG
    Thor, bang, HaarlemHoarder and 12 others like this.
  2. Shawn Curry
    Shawn Curry
    Western NY
    Yikes! Are they suspended on something out of the frame? That's the kind that's liable to stand up on you. Best to cut them from the stump end first.
  3. Erik B
    Erik B
    Western Wisconsin
    The oak is resting on its own upper branches. The poplar is hung up in other trees. Both tiped over by their roots. DSC02704.JPG DSC02706.JPG
    If a tree is allowed to stay tipped over like that for a number of months, would that lessen the chances of it standing up on you? I may not get to them until later this fall or next spring.
    Hammy, Thor, BZOR and 7 others like this.
  4. SCOTTY1848
    SCOTTY1848 Banned
    Up State NY
    Looks like ya might need a chainsaw and I see none on ur sig lol ...Homolite or Pull-On with 32" blades are the best and Wally World has them for 2.5% 48 months with free service per use and porting after two tanks of mix with sae 10wt at 16:1 but the porting guy is backed up 6+ months cuz he's busy talkin chit about other guys work!!!!!
    + makin love with 1212 dude
  5. Paul bunion
    Paul bunion
    Yes, time will lessen the spring tension on the remaining roots that will make it want to stand back up. But that doesn't mean that a lopsided root ball won't have a mind of its own.
  6. Shawn Curry
    Shawn Curry
    Western NY
    Yeah it's possible it could shift in that time and lessen the danger but from the sounds of it I'd still be careful about that oak. It's not quite like a spring pole where if it's still alive it will eventually just start growing that way. If it's still suspended on branches it's not down yet.
    Not trying to scare you off of it, just wanted to point out the potential hazard. Just be aware of the potential dangers, use your head, trust your gut, keep an eye on your kerf and what's happening as you cut, and you'll be fine.
  7. Backwoods Savage
    One root ball I remember well happened not long ago with a red oak. We cut it in the winter months so everything was frozen pretty hard. I went back sometime the next summer and found the root ball had stood back up. I had cut the base of that tree really close to the ground too and thought it would stay up but didn't.
    I usually enjoy cutting the trees like pictured.
    Shawn Curry likes this.
  8. Moparguy
    Moparguy
    TN
    I've got some of those bridges going on. It's very hilly here so it's not uncommon for a large tree on the hillside, especially in the areas with a large layer of shale, to fall over. I've got a BIG hackberry leaning against a black locust that's been dead for years and won't fall over...damm black locust with it's superior resistance to rot...
    Shawn Curry and Backwoods Savage like this.
  9. Erik B
    Erik B
    Western Wisconsin
    There is a good size crown to the oak and in addition to resting on some of its branches, it is also hung up in other trees. If I start removing weight from the crown, it may come all the way down if it looses its support. I will not be in any hurry getting the oak down. At least it is pointing down hill so gravity should help to hold it down. Thanks to all for pointing out possible hazards with this tree. I will get pics when I get to working on it.
    Backwoods Savage and Shawn Curry like this.
  10. MikeInMa
    If safe enough, you could girdle those trunks to start the drying process. Then, let time and gravity do their things.
  11. Oakman69
    Oakman69
    Mechanicsville
    Fell them From the stump, watch for kickback..i cringe with those snags
    Thor and Erik B like this.
  12. greendohn
    greendohn
    S.E. Indiana/Rush County
    Could be a trick to tackle,,be safe.
