CAD STRUCK AGAIN! Makita 3601 oh wow!
Discussion in 'Chainsaws and Power Equipment' started by CoreyB, Jul 21, 2017.
  1. CoreyB
    CoreyB
    South east iowa
    HELLO FELLOW HORDERS! CAD has struck again and I thought I just had to have this saw. Even though I already have the Dolmar 421. So I thought I would do a thread on it and show it off and see if it is worth having, worth keeping, or maybe worth selling the 421 for???
    Here is a quick video of the tooless clutch cover. I want to actually try and stay subjective on this option. As other tooless side covers I have had some bad experiences with so....
    More to come. But with work being crazy it will be slow.
    Kg461, Horkn, HDRock and 5 others like this.
  2. Oldman47
    Oldman47
    Illinois
    I watched that short video and what struck me is that the chain adjustment is relying entirely on the adjustment pin to hold the bar in position. On my saws the cover bolts are pinching the bar to hold it in place when I am done adjusting. That adjusting pin/mechanism looks like a potential failure point to me.
    Kg461, Shawn Curry and Hammy like this.
  3. Shawn Curry
    Shawn Curry
    Western NY
    I believe the crank thingy is operating a captured bar nut. MS241 and the top handle saws are all one-nutter's too, so I don't think it's necessarily any more prone to failure. Except for all the extra plastic I suppose.
    To me, it didn't really look any faster than the good old scrench method though.
  4. brenndatomu
    Yup, I have a Craftsman saw with this kind of setup. All the same things are going on, but its just basically a tool-less way of chain adjustment...the only thing inferior (on mine) is you have 1 nut holding the bar tight instead of 2.
    Hammy, Shawn Curry and CoreyB like this.
  5. CoreyB
    CoreyB
    South east iowa
    Yes that is how it is . It has two posts in place where the bar studs would normally be that keeps it from rocking and the single bar stud in between that the outside tooless wheel threads onto. It is actually a pretty hefty side cover.
    Kg461, brenndatomu and Hammy like this.
  6. CoreyB
    CoreyB
    South east iowa
  7. concretegrazer
    concretegrazer
    Southwest MO
    Good stuff Corey. Enjoy your new toy... er ...um .... tool.
  8. MasterMech
    Cool. Looks fairly robust. What will separate it from everybody else's solutions though will be what happens when it gets dirty!!! If it works just as smooth then, it'll be golden!
  9. CoreyB
    CoreyB
    South east iowa
    This is the first tank on the 3601. The 421 is for reference only.
    Kg461, concretegrazer, HDRock and 5 others like this.
  10. FatBoy85
    FatBoy85
    Washington State
    Can I ask what wood you're cutting into? Cool video!
    Hammy and CoreyB like this.
  11. CoreyB
    CoreyB
    South east iowa
    That is some oak. Some of my coffee roasting wood.
  12. FatBoy85
    FatBoy85
    Washington State
    Roasting coffee?? You got a thread here about that??
    Kg461 and Hammy like this.
  13. CoreyB
    CoreyB
    South east iowa
    concretegrazer, Hammy and eatonpcat like this.
  14. rburg
    rburg
    TN
    Is the 3601 36cc? How do the 2 saws compare weight wise?
  15. CoreyB
    CoreyB
    South east iowa
    Yes 36cc. The 3601 is noticeable lighter. At least a pound or two. I need to put them on a scale.
    Hammy likes this.
  16. CoreyB
    CoreyB
    South east iowa
    Well I took the 3601 out for a bit this evening . Still breaking in but can tell she is breathing a bit better. Can't wait till I can take it out for a full weekend of work.
    Hammy, Kg461, Armbru84 and 1 other person like this.
  17. Armbru84
    Armbru84
    Sparta, Michigan
    Looks like a good limbing saw Corey.
    Hammy, CoreyB and Kg461 like this.
  18. Kg461
    Kg461
    Provencal, La.
    Whats your thoughts Corey? 421 looks more robust from here
    Hammy likes this.
  19. The Wood Wolverine
    My first new saw purchase (years ago) was a Husky 450e with the tool-less adjuster. One of my primary wood sources is bull dozed apple trees, so I do a lot of limbing. This requires a bit more chain tension to prevent offs because of the tight quarters and hundreds of "shoots" on the tree. I really grew to dislike the set up and sold it after about one season of cutting. Stepped right up to the 357xp. I really consider this an entry level system for new users and a light use saw. Just my take.
  20. CoreyB
    CoreyB
    South east iowa
    Thank you. Time will tell.
    Hammy likes this.
