How small is too small?
Discussion in 'The Wood Pile' started by Warner, Jul 17, 2017.
  1. Warner
    I have mostly gotten delivered wood either cut and split or log length. Now that I have 6 acres to try to manage, I am cutting the dead standing trees to start. I take anything down to three inch diameter. My buddy calls them pecker poles!
    Hammy, Will C, Thor and 11 others like this.
  2. Mmjhunter
    Mmjhunter
    Pennsylvania
    I take the same as you. I just hate like hell to waste any , I like the small stuff for smaller fires or even if it's just to fill some crevices between the bigger splits or even for the fire pit
    Hammy, saskwoodburner, Thor and 10 others like this.
  3. Splitsnstacks
    Splitsnstacks
    Sw pa
    Honestly, the only stuff I keep that small is the high btu stuff. It's wasteful, as I leave a lot of tops lay but I do try to use the small stuff for smoker wood though.
    Hammy, Backwoods Savage, RCBS and 3 others like this.
  4. yooperdave
    As the temp goes up, so does the size!
  5. HDRock
    Pecker poles , equal far :woodsign:
  6. brenndatomu
    I take down to 2", sometimes even smaller if it is straight with few/no branches to trim...if the small stuff is much work at all to trim up, its gone. I like having a variety of sizes to pick from when loading.
    Hammy, saskwoodburner, Thor and 13 others like this.
  7. Warner
    That's my thought, I have some rather large splits as well. Variety is key for me
  8. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I try to go down to two or three inches. I jam them in between the 12 inch rounds, and start the morning fire with the small stuff. I get less picky when I have a lot down, but it all burns!
  9. Warner
    Those sleds have so many uses. i keep one without holes for ice fishing to keep the gear dry. Eventually they wear a hole then I use them like you. Hauled deer to rocks.
    Hammy, Splitsnstacks, Thor and 9 others like this.
  10. Horkn
    Same here. I take down to 2" diameter. I also like large splits, so I can pack the stove and post on the "stove Tetris" thread.
  11. NH mountain man
    NH mountain man
    WMNF N.H.
    Same here, I burn a bunch of the small stuff in shoulder season for an hour or two to take out the chill in the morning.
  12. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I like the smaller trees you don't have to split them and they burn a little hotter and longer not split. Don't get me wrong I'll cut just about anything size wise but I do like the smaller rounds.
  13. NH mountain man
    NH mountain man
    WMNF N.H.
    And the smaller stuff dries quicker if you are a newbie trying quickly season wood.
  14. Pallet Pete
    Ovid
    Yes indeed...
    Many times it's already dry too.
  15. MikeInMa
    Small diameter pieces can be split further and used as kindling
  16. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    I cut saplings down to 3" or so. I cut them 8' long then process them on my cordwood saw.
  17. Backwoods Savage
    It all depends.
    Many times we will take the real small stuff and more so when my wife is with me. However, it does take more time to collect a lot of firewood if you are taking the small stuff. In addition, at present we have a lot of wood going to waste because of the EAB so why should I spend time getting the really small stuff when lots will go to waste anyway. I'd rather spend the time getting the bigger wood while it is still worth getting. In time we'll probably go back to getting the smaller stuff but right now unless it is oak, we don't get the 2-3" branches; just leave them in the woods.
    HDRock, Hammy, saskwoodburner and 6 others like this.
  18. Will C
    Will C
    New York
    When I cutting in my brother's woods, I cut quite small-more for the aspect of cleaning up the woods than for the wood value. "Pecker poles" do take up a lot of time for the amount of wood you get from them.
    Viking80, HDRock, Hammy and 5 others like this.
  19. Warner
    This is my thought exactly. Trying not to have brush piled everywhere
    Viking80, HDRock, Hammy and 3 others like this.
  20. NH mountain man
    NH mountain man
    WMNF N.H.
    Might as well use the btu's.
