string trimmer reccomendations?
Discussion in 'Everything Else (off topic)' started by yooperdave, Jul 6, 2017.
  1. yooperdave
    I call them weed wackers; I believe the rest of the world refers to them as string trimmers.
    Looking for one with a gas engine (would consider 4 stroke) and would like to hear how everyone's has worked out for them.
    How long/how old/reliability/any issues sort of answers.
    Been using an electric one for years and hope to move away form that.
    Thanks.
  2. bocefus78
    bocefus78
    I run 2 stihl fs90r commercially. At the time of purchase, they were the smallest straight solid shaft commercial trimmer sold. For the past 5 years or so, the one and only problem was a clutch bearing in the one that gets used the most.
    If you are over about 5' 6" you want a straight shaft as they are longer and keep you from bending over.
    Eric VW, Thor, RCBS and 9 others like this.
  3. yooperdave
    Thanks! Now thats the type of insight I'm hoping for!
  4. MasterMech
    I second the straight shaft recommendations.
    Four stroke is ok, but I like the two stroke whipper snippers better. Stihl's 4-mix engine is fine but you still need mixed fuel for it.
    If I wanted to buy a pro-quality trimmer today, it would probably be a Stihl FS94R. Or something from the Echo line up if you are looking to save a few $$.
    EDIT: my personal machine is a Stihl FS110R.
  5. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
  6. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Go with commercial, straight shaft. Stihl, Echo, maybe even RedMaxx. They will last a long time for a home owner. My Echo is now 14 years old and only been in the shop once for the carb.
  7. JustWood
    JustWood Guest
    I went all in and got the FS130R a few years ago.
    I wanted the power to run multiple head options .
    Should never have to buy another trimmer the rest of my life .
    Eric VW, Thor, RCBS and 7 others like this.
  8. bocefus78
    bocefus78
  9. Jack Straw
    Jack Straw
    It saved us a lot of money at the cemetery, the gearbox went and that extended warranty covered it. I agree about the smell though.:eek:
  10. ironpony
    ironpony
    Mid Ohio
    Redmaxx best one built
    RCBS, Backwoods Savage and Chvymn99 like this.
  11. Chvymn99
    I've got the lightweight Redmax, had it for about 4 or 5 years now. Its got good power to weight ratio, I put on the tap and go head on it and love it. I bought Dad a Echo two years ago for fathers day, that similar to it and he loves it....
  12. blacksmith
    blacksmith
    central Pa
    Me personally I'd go with the Kombie system. I ha e a KM 55 with a few attachments and I absolutely love it!:thumbs: Especially they adjustable hedge trimer you can easily trim the tops of bushes 8ft tall! And I can't forget the pole saw that's a real lifesaver. But you may not have bushes and tree's like I do to justify the attachments.
    Eric VW, RCBS, VOLKEVIN and 2 others like this.
  13. papadave
    This is timely, as I'm looking too.
    I bought a Troy-built 4 stroke from HD or Lowes a few short years ago, and it always seemed to bog down in any tall/thick stuff.
    I'd like one that has the ability to trim small trees/branches as well as weediewhack.
    Eric VW, yooperdave, RCBS and 4 others like this.
  14. Jack Straw
    Jack Straw
    I have this and love it! FS90
    Eric VW, Thor, yooperdave and 5 others like this.
  15. Canadian border VT
    I have stihl kombi ... 130r way over kill for just string line.. but love pole saw.. and little tiller and power broom .. 6 years hard use lost split shafts spline (operator error) fixed at dealer 65 dollar while I waited.. over 6 foot no bending 2 stroke same gas as saw
    Eric VW, RCBS, VOLKEVIN and 5 others like this.
  16. papadave
    Sorry Dave, but maybe this will help you too.......I think the sling would be a great option for me, as my back is in less than stellar shape.
    CbVT, the pole saw would be great and so would a little tiller to get between the raised garden beds.
  17. Canadian border VT
    the thing goes that great too BUT awesome to remove tire ruts from lawn! hoarders know nothing about that:whistle:
    Eric VW, yooperdave, RCBS and 2 others like this.
  18. papadave
    Might have to break down and buy something other than a homeowner special. :whistle:
    We have a battery powered Black & Decker that I bought when we lived downstate and had a postage stamp sized lawn. It doesn't even come close to doing the job up here.
  19. Backwoods Savage
    Not sure how much of a weed whacker you need but for this guy, I got really tired of them except for on big one I bought many years ago from Sears. However, I have not used it for several years now.
    Depending on how much you have to do and how heavy of a job it is, you might consider one of the cordless but here, bigger is definitely better. We got a 40 volt ryobi and love it. It can do very close to what the Stihl did for us but no more screwing around with the 2 stroke and no more recoil starter, which is why I switched.
    The 40 volt will do a good job even in some tall weedy stuff and can do it almost as fast as the Stihl we had. Depending upon if you run the machine at full speed, the battery will last from 35 minutes to close to an hour. I think I got 58 minutes run time once. I don't remember how long it takes to recharge but I think it is way less than an hour. We've had it for a few years now and still like it.
    Eric VW, yooperdave, papadave and 2 others like this.
  20. lukem
    I recently bought an Echo SRM266. At first it seemed a little under powered but after a few tanks of fuel it runs great.
    Very easy to start. Solid shaft. Cheaper than a Stihl. 5 year warranty.
