Need some body work advice
Discussion in 'The DIY Room' started by schlot, Jun 24, 2017.
  1. schlot
    schlot
    NW Iowa
    Starting back up on removing the old vinyl top on the 1967 Newport. I'm standing down the surface rust and putting primer on it before we ship it off for a new top.
    I threw a 60 grit disc on the angle grinder and it looks like it will take forever to get the top done.
    I am thinking about just using the regular grinding disc with caution to get through the paint since it will be covered up with vinyl anyway.
    Thoughts?
  2. Locust Post
    Wire wheel on an angle grinder, 36grit, then 60 or 80.
    TurboDiesel likes this.
  3. TurboDiesel
    A 60 grit flap disc should take that paint off fast
  4. schlot
    schlot
    NW Iowa
    I did try that before. Painfully slow.
    I did use a grinding disc on the angle grinder to get through a small portion before you and Locust Post posted. I figured as long as I was careful and since the finish will be covered by vinyl i would be ok.
    But I might try the wire brush if I can find an adapter for my Makita angle grinder.
  5. TurboDiesel
    We strip paint all the time with flap discs.
    Can't imagine anything any faster:confused:
    Jack Straw likes this.
  6. schlot
    schlot
    NW Iowa
    Oh sorry....i didn't read the "flap" part.
    I saw them but they were 4.5" diameter. I use 4.0" discs now.
    I will take a better look and see if i can find some that will fit. Thanks.
  7. wildwest
    Very Cool!
  8. trail twister
    trail twister
    See you have gotten the dreaded photo bucket hold 3d party picture posting hostage notice.
    Switch to postimage.org. Easy to use free and works well.
    Share menu
    thumbnails for forums.
    Hot links for forums.
    :D Al
    will711, eatonpcat and schlot like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    off topic but that is some pretty tomatoes. Mine are only just recovering from the two floods.
    schlot likes this.
  10. schlot
    schlot
    NW Iowa
    Thanks...will look at that. Unfortunately the oodles of pictures I posted already all have bad links now. :(
    Not sure if Grizzly Adam has any idea about what I can do with the previously posted pics?
  11. Grizzly Adam
    Grizzly Adam Guest
    I would just recommend uploading files here instead.
  12. Kimberly
    Kimberly
    The Kangaroo State
    I wouldn't worry about changing them at this time; if someone revisit a thread and the picture is needed, you can upload it at that time. Any time content is third party, one risks the content disappearing. Here is an example, there was a javascript library used by millions of sites around the world. Instead of having a local copy of that javascript code, million of sites just linked to it and loaded it from the remote site. When the javascript code disappeared, millions of sites became broken. As Grizzly stated, FHC has the space for you to load your images to the FHC servers.
  13. trail twister
    trail twister
    But what if you want to share your garden pictures here and and on the other fire wood chain saw site and a garden forum or two and a varmint hunting site like I have done and still do with a new 3d party server.
    :D Al
  14. schlot
    schlot
    NW Iowa
    There's another firewood site?! Heresy I say!! :)
    That was the reason I started using Photobucket...but anymore this is the place I bother people....er I mean contribute to anymore. :)
  15. Kimberly
    Kimberly
    The Kangaroo State
    If they allow photo uploads, I load to all the sites where I post. As you have seen here, when a photo hosting site goes down or blocks because of bandwidth, everywhere on the interweb you have posted, your photos are not showing.
    papadave and schlot like this.
