Harman advance door latch
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by corkman, Jun 23, 2017.
  1. corkman
    corkman
    Southeastern mass
    I'm finally getting around to installing the 2014 advance that I picked up a few months ago. It's going right where the old one was so a pretty easy swap out. Got stove in and prepped it for the summer. Put the door on and not happy with how it latches. Failing the $1 bill test big time. Check out the bushing. Completely worn down to the point that when I engage the latch it barely even moves the spring. Went to dealer but he doesn't stock them. Had to order but they only come in packs of 5 I guess. There's 2 bushings and they are different diameter according to parts list so I had to order 5 pack of each to the tune if $33. Anyone ever experience this
    ivanhoe likes this.
  2. corkman
    corkman
    Southeastern mass
    Parts list
    ivanhoe likes this.
  3. Lousyweather
    Lousyweather
    can you use a sleeve bearing? Might actually work.....its really just a roller
    gbreda, imacman and ivanhoe like this.
  4. corkman
    corkman
    Southeastern mass
    I'll see if I can get my hands on something to make it work. Any suggestions on where to find a sleeve bearing
  5. jtakeman
    Any industrial supply house should be able to get them. Graingers is a good start.
    Let me know if ya get stuck or can't find one.
  6. corkman
    corkman
    Southeastern mass
    There's a Fastenall store not too far from me. Maybe I'll check it out Tuesday
  7. gbreda
    gbreda
    NH
    Time to get creative.
    Try a local hardware store like Ace or Aubuchan-not big box store. I have used one in Kittery ME and two places in Alton NH to Macgiver many repairs at home and at my honeys place.
    These small hardware stores will have entire aisles of draws with almost anything you can imagine. If you havnt checked these types of places out lately you will be amazed at what you can find....and you can buy one, two or as many as you need at very low cost.
    ttdberg, Lousyweather and jtakeman like this.
  8. corkman
    corkman
    Southeastern mass
    Put the new bushings in. While there's improvement the door seal isn't where it needs to be. I have a tight seal everywhere except for the top of the door. Fluffing up the gasket helps but I think I'll replace it now before the season hits. I was gonna head to the dealer but thought I'd take a quick look on line 1st and found 2 different gaskets .I remember changing the gasket on my 2004 advance and it was the lighter colored one. This gasket that needs to be replaced looks like a graphite gasket. The lighter color one says it's a tadpole gasket and OEM. They both have the same part number. Which one ?
    jtakeman likes this.
  9. don2222
    don2222
    Salem NH
    I think they are very similar. The Advance must use a tadpole gasket because it goes under the bracket that helps hold the glass in. So the OEM gasket is the one to use. Can you replace mine too. :)
  10. corkman
    corkman
    Southeastern mass
    It'll be interesting to see which one my dealer carries. Definitely the toughest door gasket to do of all the Harman stoves. Hey don. I'll do the stove for you if you want to drive the 90mins to drop it off
  11. don2222
    don2222
    Salem NH
    LOL
    I just have not had the time! It may be good training for one of my helpers. :)
    Do you think high temp Mirror Glass would look good in the Advance???
    Updating a pellet stove fire door to high temp German Engineered mirror glass?
    Looks good in this old PP38+ ??
  12. corkman
    corkman
    Southeastern mass
    I'm sure it would. Mine is a cellah dwellah so no mirror glass for that. I do love it in my xxv upstairs though
