Playtime!
Discussion in 'The Wood Pile' started by Shawn Curry, Jun 17, 2017.
  1. brenndatomu
  2. brenndatomu
    My buddys old Ford Bronco II would do wheelies...course it had a 351 in it...:whistle:
  3. TurboDiesel
    Pics...or it didn't happen...:D
  4. brenndatomu
    That Rancher will do a wheelie too...just scoot back so you are sitting on the rear rack...pull the shift lever up and hold it...give 'er a lil gas and then let the shift lever drop... :whistle:
    (may not be officially endorsed by Honda Motor Co) ;)
  5. brenndatomu
    Sorry, that was a few years ago now...before everybody was walkin around with cameras in they pockets!
    94BULLITT, Eric VW, Chvymn99 and 3 others like this.
  6. Hellcat
    Hellcat
    Centre Hall, PA
    See Shawn,it can be done! No pix necessary brenndatomu, I totally believe you:yes:
  7. Armbru84
    Armbru84
    Sparta, Michigan
  8. Backwoods Savage
    Just a little hint here Shawn. Hook that chain a lot shorter and the pulling gets easier.
    walt, Woodwidow, Eric VW and 5 others like this.
  9. brenndatomu
    Yeah, get it short enough and the front of the log will lift some when you pull...transfers more traction weight to the rear tires of the quad too. I've seen guys use an old piece of metal roofing, even an old car hood under the front of the log to help keep it sliding well without digging in.
