Stale gas and ethanol baahh!
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Jun 1, 2017.
  1. clemsonfor
    I use plenty of one year old gas. Not in my saw normally but in gas stuff like mowers and old trucks all the time.
    blacksmith likes this.
  2. MasterMech
    Amazing, I grew up with a 966 Hydro affectionately named "Big Red". It wasn't the biggest tractor on the farm by then but it did a lot of work. The owner considered it his favorite and loved to run it for hay work. That tractor spent a LOT of time hooked to the square balers and bailed hundreds of thousands of bales.
    Letter series farmalls (3 Hs and 3 Ms, no supers) did all the small work too.
    blacksmith and brenndatomu like this.
  3. cwn877
    cwn877
    Central Pa
    That's what are 10 does mostly too. I can't feed the baler enough to haul the tractor down.
  4. brenndatomu
    That's probably double the HP it would take to effectively run that baler :whistle: :thumbs:
  5. cwn877
    cwn877
    Central Pa
    Well the 1066 stands for 106hp 6 cylinder but most of them were closer to 125 go so yeah it is probably 3 times what it takes.
    blacksmith and clemsonfor like this.
  6. clemsonfor
    Well those are easy model numbers to decipher one you know the structure.
    blacksmith and cwn877 like this.
