Stihl 038 Super to ported 038 Mag build -Part #1 (pic heavy)
Discussion in 'Chainsaws and Power Equipment' started by ChipsFlyin, Jun 5, 2017.
  1. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    In the beginning there was a dirty beat up Stihl 038 Super. DSCN5102.JPG DSCN5104.JPG DSCN5127.JPG DSCN5129.JPG
  2. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    After a quick bath.
    Have to keep all of the parts labeled or I'll get lost putting it back together. DSCN5130.JPG
  3. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Paint stripper in place.
  4. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Getting there. Carb kit in. Waiting for p/c, handle and AV parts plus smalls. Custom labels made. It will be a 72AVP (72cc antivibe ported). Plastic covers sanded with 150 grit. They will be dyed black before painting just in case the paint chips- you know it will... I will continue once I start painting and tearing more stuff apart.
  5. cnice_37
    cnice_37
    Are you doing the grinding on the jug?
    I had a Super turned Mag, definitely a grunty saw.
    Leadfarmer and blacksmith like this.
  6. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I have the carbide burs ready to go. I did some on my Poulan 3300 that turned out decent so might as well jump in with both feet. Once I get the p/c in and mounted to check the squish I will make a plan. I do not have a mill so hoping with a gasket delete it will will be close to 20. If it's much more I will try figure something out old school. After that I'll get the timing #'s and most likely send out a post to see where I should go. There are 6 threads on another forum that go into porting quite extensively - Exhaust port, intake port, transfers, compression, ignition timing, and exhaust in that order. I have all of them bookmarked for reference and will restudy them as I go. At least that's the plan. Plus, the aftermarket p/c's are cheap enough that it takes some of the fear out of messing up. Well see what happens. My goal is to be at right around $300-325 for the entire build which includes the saw, parts, paint drum conversion, bar and square chain. If all goes right I might be a bit under.
  7. blacksmith
    blacksmith
    central Pa
    Are we going to see that saw at next year's PA GTG? :whistle:
    Leadfarmer and ChipsFlyin like this.
  8. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I would like to have it done by the end of summer. Super busy for the next couple weeks so will do a little here and there. Ir probable will not be close to the other builds that were at the GTG but should run better than stock.
  9. Mag Craft
    I am interested in seeing what it looks like with the colors you picked out. Good for you porting your own saw. You do not have to go crazy, after all we are not building race saws just good cutting
    working saws.
    Leadfarmer, blacksmith and ChipsFlyin like this.
  10. blacksmith
    blacksmith
    central Pa
    I must say you seem very neat and organized with your set up to keep parts in safe a place during the build!:thumbs: Unlike some other people that I know I am not naming names, but I will including myself! :rofl: :lol::rofl: :lol::doh:
  11. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Covers stripped, sanded and Stihl logo removed. Maybe an coat of sandable primer tomorrow.Going to redo the tags and add some color like a lighter gray than the paint.
  12. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Covers with 2 coats of primer inside and out.
    2 coats of paint inside and out. It's a weird combination of color but think it will look nice all installed. Sorry had to do the pic inside - ran out of light. They will sit for a few days before they get cleared. I had trouble figuring out colors for the tags so went with something kinda in between the gray and teal. Will punch holes in the tags so the fit over the rivets.
  13. Mag Craft
    Some pretty cool stuff.
  14. PA Dan
    PA Dan
    White Oak Pennsylvania
    Hey Mark glad to see your diving into that saw!
  15. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    There's no play in the main bearings and plenty of carbon on the piston so pretty sure it was getting enough oil for lubrication so not splitting the case. The seals will be in the kit so might as well do them when get rest of it apart for paint.
  16. PA Dan
    PA Dan
    He Mark if you want to split the case I can help you out with that!
  17. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    I appreciate the offer. :handshake: I'll PM or text you down the road. :)
    blacksmith, Leadfarmer and PA Dan like this.
  18. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    Had an old 16" Total Tsumura bar sitting around. The oil holes match right up so decided to strip and clean it up. 10mm slot so guessing an 024 Jonsered mount. After a bit of widening and making sure the adjuster fits it should be a nice addition to the build. DSCN5195.JPG
    blacksmith and Leadfarmer like this.
  19. Unicorn1
    Unicorn1
    Amarillo, TX
    Nice work on the Stihl.:)
    blacksmith, Leadfarmer and ChipsFlyin like this.
  20. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
    PM'd you on AS. For some reason FHS will not let me start a conversation with you.
    blacksmith and TurboDiesel like this.
