Why is this chain not sharp?
Discussion in 'Chainsaws and Power Equipment' started by NBourque, Jun 5, 2017.
  1. NBourque
    NBourque
    Stihl RS chain just sharpened at a stihl dealer.
    savemoney likes this.
  2. The Wood Wolverine
    If I had a dealer sharpen a chain, and it wasn't sharp, I'd have not paid or taken the chain home.
    It appears to me as though the chain was rocked or damaged back farther than the dealer ground it. Maybe he just touched it up when it needed ground back farther to remove all the damage from the cutters?
    Hinerman and 94BULLITT like this.
  3. NBourque
    NBourque
    This is what I'm thinking. I had been cutting into some wood that had nails in it. When I brought the chain in I mentioned this to them.
  4. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    This is why you sharpen your own chains. It was probably some 14 year old stoned fricker doing it who could give 2 chits about what he's doing. You can get a cheap 20 or 30 $ electric sharpener off Amazon and save the hassle and your chit will be much safer in the long run.
    30 magazine clip on my ghost gun
  5. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    chit. fricker. Stupid autocorrect lol
    FatBoy85 likes this.
  6. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Oh snap the forum does it!!!!! You sobs got me good lol
  7. Nixon
    Nixon
    West Sunbury,Pa .
    Looks like the working point is bent down. If the chain can't get the working point started in the wood , it won't cut well at all . The guy running the grinder didn't grind it out .
  8. NBourque
    NBourque
    This is the second stihl dealer I've brought chains to that can't sharpen chains worth a damm.
    clemsonfor likes this.
  9. NBourque
    NBourque
    Is this chain worth filing by hand? My chain sharpening skills are not the greatest.
  10. Chvymn99
    If there is any incentives to sharpen your own chain, that's it right there. Northern Tools has a good base line grinder for $100, quite often, just for it to go on sale. That and get a set of file and learn, it'll be worth it in the long run.
  11. Chvymn99
    If it's been nailed or rocked, it'll be hard to do it by hand, but not impossible.
    mirnldi, walt and Barcroftb like this.
  12. NBourque
    NBourque
    I feel like I can maintenance sharpen a chain but a chain that has been damaged by a rock or steel is very hard to sharpen for a novice like myself. This is why I had it "professionally" sharpened. This chain brand new cut thru wood like I've never seen and now it sprays out sawdust
  13. Nixon
    Nixon
    West Sunbury,Pa .
    No time like the present to pick up the skill ! :D If you don't want to go to the cost of a grinder , get the Stihl file and guide set for your particular pitch chain and the Stihl FG 1 guide holder for that pitch chain . Makes filing pretty easy to pick up .
    Barcroftb and Chvymn99 like this.
  14. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Dude... Amazon. Cheap grinder for 30 bucks. I do 70 cord a year at times. It gets me by. I am on season 2 on the same cheapo grinder. Husky 460. 24"
  15. HDRock
    Looks like he was hitting it too low and didn't sharpen the top of the teeth
  16. HDRock
    Pretty sad when you take your chain to a Stihl dealer and it comes out like this
    Chvymn99 likes this.
  17. brenndatomu
    Exactly what I was thinking...used too small of a stone...or file...whatever, for this chain
    Chvymn99 and HDRock like this.
  18. HDRock
    I was thinking that too, maybe he used the wrong size wheel
  19. KsKent
    KsKent
    NE Kansas
    I say the chain is definitely worth sharpening with a file. I am not saying you shouldn't get an electric sharpener or a bench top, but with a sharp file you can fix that chain in just a few minutes for a very few dollars. Your file can go to the woods with you and you can touch up your chain when you fuel up, if needed. You can learn to do it in no time. You may want to have a neighbor or friend help you the first time or two.
  20. Kyle Mulligan
    Kyle Mulligan
    North Greenbush, NY
    The rakers get progressively lower in each pick. Top raker is not touched and last pic looks like it got dropped to .025. Are all these picks after sharpening?
    The top plate does not not look sharp to me either. I can't tell about the side plate. Bottom line they did a crappy job take it back and have them fix it.
    I have used a bunch of sharpening tools and my fave is a granberg 106b jig. Short learning curve and flat works.
