Interesting article on alternative heating
Discussion in 'Everything Else (off topic)' started by raybonz, Feb 23, 2014.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
  2. Scotty Overkill
    Great article, Ray......that's up somewhere by Woody's place! Maybe he can go and do an interview with the guy for the FHC!
    Thanks for sharing this with the club, brother!
    raybonz likes this.
  3. raybonz
    raybonz Moderator
    Carver, Mass.
    Relatively unbiased I thought and more accurate than many other articles I've read.. Found it on FB..
    will711 likes this.
  4. will711
    will711
    Pocono Mts.
    It was a good read thanks . I thought it was interesting that Curan the pellet guy said they could produce more and sell more if he had better cash flow in the off season ... hmm. I'm not a business person ,but seams to me you could maybe get a short term loan . Run the numbers cost of the loan and production vs increase sales does it = a profit?? shoot a whole in my thoughts if I'm off base.
    raybonz likes this.
  5. Paul bunion
    Paul bunion
    The article said he burns 25-30 face cords to heat a 2000 sq foot house with a masonry mass stove. Assuming 16" length that would be 8-10 cords which is an awful lot of wood. If that is correct it is far from being efficient.
    TurboDiesel and raybonz like this.
  6. raybonz
    raybonz Moderator
    Carver, Mass.
    IIRC they have the house at 80 degrees too.. I use much less wood (guesstimate 4 cords max a year) for 1600 sq. ft. but it isn't as cold here as there.. I would find 80 degrees too hot with anything over 75 too much.. Generally I found the article more accurate than many I have read and that was my main point..
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    I'm with you! If I were the manufacturer of pellets I would be producing what I felt would be sold in a year.. Lean manufacturing is OK if done correctly.. If done too leanly you will lose customers and that could be forever! I work for world's largest maker of razors and keeping our customer's shelves stocked is important or we will lose business.. This sort of thing is tracked by the company ..
    will711 likes this.
  8. will711
    will711
    Pocono Mts.
    He also said he would like to develop a pellet reserve , When I worked for garden centers we would buy our peat moss and fert early ie Jan and take delivery in Feb. We only put down 20% rest wasn't due until May /June it's a win win , we helped them out in the off season , we had the product when the season crunch hit not waiting for delivery, just my 2 cents.
    raybonz likes this.
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    hmmm, I didn't see any text in the article just a couple pictures???
  10. raybonz
    raybonz Moderator
    Carver, Mass.
    You have click on the question thing then the text appears..
  11. will711
    will711
    Pocono Mts.
    Had to take a survey 1st before the text came up.
  12. My IS heats my home
    My IS heats my home
    Albany, NH
    gotcha...will do
  13. Certified106
    Certified106
    In The Hills
    Good article, thanks for posting it.
    raybonz likes this.
  14. My IS heats my home
    My IS heats my home
    Albany, NH
    raybonz likes this.
  15. nate
    nate Banned
    Palmer, AK
    The claim of having the house door open for an hour at -20* and the house temp dropping 1*.... Does that make sense?!
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    Maybe they raised the outside temp one degree? lol
  17. Daryl
    Daryl
    I love masonry but the stoves don't perform any better than metal stoves. At one time I believed the hype about rocket mass heaters but they have turned out to be as efficient as metal stoves, sometimes worse. I have been scouring different forums to get an idea of the average cord use in a year. It is relatively the same result with the metal stoves performing a little better, especially in cold climates.
  18. TurboDiesel
    It does seem like a stretch ,but if the house is so tight that heat doesn't escape then the cold air wouldn't flood in.
    Think of your house as a chimney. When the hot air goes out the top the cold air is pulled in every little crack to replace it.
    The claim may be possible.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    You can only get so many BTU's from a pound of wood.. Efficiency dictates how much heat stays in the home or goes up the chimney..
  20. Daryl
    Daryl
    Ok. I was basing that comment various factors and maybe I didn't word it correctly. I don't want to get into details now so I will back off the thread. Cheers. :)
    raybonz likes this.
