Junk Damaged Trees
Discussion in 'The Wood Pile' started by thewoodlands, Jun 2, 2017.
  1. thewoodlands
    thewoodlands
    The first tree was damaged last fall but I was counting on the winter to take it down, after the strong breeze the other day it was down lower to the main trail so we pulled on it but it didn't want to come out of the Sugar Maple so we kept good tension on the cable and then I started with the saw which did the trick.
    The second tree was overhanging the main trail and splitting apart so I made a notch and then used a bore/plunge cut........worked perfect.
    The first tree was a Big Tooth Quaking Aspen and the second was a Basswood.
  2. HDRock
    Mother Nature is slacking making you do some of the work:saw::tree:
  3. Lincolnland
    Lincolnland
    AU
    that green looks delicious
  4. Well Seasoned
    Nice work Woody! Looks a bit tricky. Glad it came down! :saw:
  5. Moparguy
    Moparguy
    TN
    I was scrolling through your pictures and the one where the tree is blocking the driveway and gone the next with just the top laying behind was funny.
    So aspen is what you guys call poplar right...similar to the tulip poplar we have in the south?
    In the Pines, HDRock, Hammy and 3 others like this.
  6. thewoodlands
    thewoodlands
    It's always nice to see it green up.
    Well Seasoned , if I would've brought the tractor or had the cable up higher towards the top , it would've come down.
  7. thewoodlands
    thewoodlands
    Yes, I use to call it that until I was corrected.
    In the Pines and NH mountain man like this.
  8. thewoodlands
    thewoodlands
    The real work will start after Sunday with the stacking, we'll see how much rain we get.
  9. thewoodlands
    thewoodlands
    The branch in picture 0292 came down in May from the tree in picture 0293, it's not the best Sugar Maple but it will throw some heat. The hanger in picture 0295 has been like that for two years so hopefully before winter it will come down.
    The broken down tree in picture 0296 is an Ironwood I'll get next week.
  10. thewoodlands
    thewoodlands
    The deer were hitting the Basswood leaves today, I only was able to get a picture of one. 100_0298-001.JPG
  11. Well Seasoned
    :thumbs:
  12. Timberdog
    Timberdog
    Az
    Not to nitpick but I believe Big Tooth is one type of Aspen and Quaking is another....
  13. Well Seasoned
    Is quaking the same as trembling? Trembling Aspen here :D
  14. Timberdog
    Timberdog
    Az
    Yes.
    Well Seasoned likes this.
