Ash tree is lookin a little scary
Discussion in 'The Wood Pile' started by HDRock, May 28, 2017.
  1. HDRock
    Only reason it is still there is because I have to cut the fence and put it back together
  2. papadave
    That thing's seen better days.
  3. Hinerman
    Hinerman
    NE Oklahoma
    Yep, it's time...
  4. HDRock
    Gee, there's another little one I didn't see until I looked at the picture:whistle::binoculars:
  5. papadave
    Can't see the tree for the forest?:):woodsign:
  6. Moparguy
    Moparguy
    TN
    Nice shagbark ash you got there...
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Careful with that thing. Those upper branches could give you a headache you will never forget. o_O
  8. HDRock
    That's what I'm talkin about.
    Some of the branches extend into other trees too
    I will make some Cuts but then, I will be a long ways away when I pull that sucker down.
  9. Armbru84
    Armbru84
    Sparta, Michigan
    Time to get that bad boy on the ground.
  10. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Are you sure that ain't rotten?
    Eric VW, Backwoods Savage and HDRock like this.
  11. HDRock
    Naw, I don't think it's rotten but I need to do some more inspection around the base before I do anything
  12. Jack Straw
    Jack Straw
    Well, I bet it's dry!
  13. HDRock
    Snap crackle pop dry, I'm going to be dropping it into my yard so I will have a big mess.
  14. Backwoods Savage
    It might be misleading but that looks like it leans away from the fence. If so, you can cut without cutting fence. If not, worry not as sooner or later the tree will take care of that part about taking the fence down.
  15. HDRock
    It does lean away but I don't want to drop it into the creek that's right there , can't see the creek in the pic.
    Actually it wouldn't fall into the creek, to many trees in the way to fall that way, it will just get hung up.
  16. yooperdave
    damm those bugs anyway.
  17. wildwest
    Are you going to try to save your ash or cut it and be a smart ash?
  18. yooperdave
    Anything else would be a dumbash
  19. TurboDiesel
    Get the hardhat out for that one HD!
    It will be easy to clean the yard up after. Just rake all the little "Tootie Rolls" into a pile and burn them.
    Thats what those branches will look like when the top hits the ground.
  20. Gark
    Gark
    SW Michigan
    A hundred times what yooperdave said.
