Unfamiliar territory..... MasterMech uses a nail gun...
Discussion in 'The DIY Room' started by MasterMech, Jun 13, 2016.
  1. lukem
    This guy should not have been allowed to frame.
    savemoney and MasterMech like this.
  2. MasterMech
    It's a lot better when you imagine the "structure" of the old wooden box in place. That wall was built around the box, which appeared to have been modified at some point to make it taller. So 2x the patch jobs. But I would swear he built the whole mess out of cut-offs from the garage construction.
    TurboDiesel likes this.
  3. MasterMech
    So......:emb: it's been over a year since my youngest son was born and I started this project. But I can finally say it's done! (Nearly....) (Work, crazy hours, other remodel projecst, life getting in the way, you guys have heard them all!!)
    Here's the tank in place and the supply manifold built. Just have to connect it to the house now.....
    And ....
  4. HDRock
    Nice job man :thumbs:I know who to call when I do mine:)
    I bet it feels good to be finished:smoke:
    savemoney, Chvymn99, Eric VW and 2 others like this.
  5. papadave
    Very clean sweat job. Nice.
    A year? Rookie. My projects take much longer than a mere year. :picard::rofl: :lol:
  6. Eric VW
  7. Chvymn99
    Nicely done! :handshake:
    Eric VW, HDRock and papadave like this.
  8. Stinny
    Nice job mistah mechanical man... :dex:
    Eric VW, HDRock, savemoney and 2 others like this.
  9. ironpony
    ironpony
    Mid Ohio
    You have been without water for a year.......:faint:
    HDRock, savemoney, cnice_37 and 2 others like this.
  10. Canadian border VT
    pretty work MasterMech! I think a year is wrong... how many working hours did it take you less than 40?... it just took a year to get that 40 done!
    Eric VW and HDRock like this.
  11. MasterMech
    Just getting the system piped (replaced aging incoming service line from the well) and the manifold build took much longer than I anticipated. Of course I'm working on my garage floor, for which my knees have no kind thoughts. And with the most basic hand tools, no fancy stuff from my (former) employer. My kingdom for the pipe vise and a couple 18" pipe wrenches.
    I had one problem with a solder joint, caused by adhesive residue on a fitting where a
    sticker had fallen off. Apparently I did not notice the residue and my fitting brush does not remove the residue 100%. The joint appears to sweat just fine and it held for a few minutes before it popped out a small chunk of solder and started pizzing water everywhere. :doh:
    But nothing gave me more trouble than the threaded joints and the bloody unions. Had to take apart the section connected to the tank tee and re-prep/re-install those two 1 1/4" male adapters. Then had to play with, and eventually replace the unions connecting the sediment filter to the manifold.
    Chvymn99, Eric VW, HDRock and 2 others like this.
  12. MasterMech
    nah. Moved the old pressure tank, filter and switch, and did some "temporary" reconnections so I could build the new system with minimal interruptions in service to the house.
    Chvymn99, Eric VW, HDRock and 3 others like this.
  13. savemoney
    I know first hand how frustrating plumbing joints can be. That is why I no longer even attempt to do them. Now have a professional plumber come in. He comes, leaves and it is all done. He takes a fat check with him, but my mind is at ease and my blood pressure didn't go up. I'm not able to get up and down or climb so that sort of did it for me. Your system looks good. You should be able to get to it should the need come up.
    Jack Straw, Eric VW and HDRock like this.
  14. MasterMech
    Hopefully the next owner enjoys it and appreciates the work that went into it. I'm relocating for work so I will get very limited use of it!!
    Boomstick, Chvymn99, cnice_37 and 3 others like this.
  15. Stinny
    You comin to Maine? :D
    milleo, papadave, MasterMech and 2 others like this.
  16. Eric VW
    Got a new owner lined up?
    papadave likes this.
  17. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    That's purdy!
    papadave, Chvymn99 and Eric VW like this.
  18. Canadian border VT
    too what area?
  19. MasterMech
    No sir. Working on that. Have been buttoning up all of the "projects" and prepping it for listing. Wanna live in NY? :rofl: :lol:
    Thank you sir!
    Greenville, South Carolina
    Boomstick, Stinny, savemoney and 4 others like this.
  20. Eric VW
    Been there, done that.... from birth til HS graduation, and for a few years later on.
    :faint:
    :salute:
    Chvymn99 likes this.
